Mustang takes forever for rpm's to drop
I have a 1996 GT and i don't think anything is wrong with the engine but for some reason the rpms dont come down really that fast.. Its really hinders my shifting because the rpms are really high when the clutch goes in i can't hammer down on the next gear. I can still shift pretty good but if i go to hard it doesn't accept the gear. Does my car have like a 10,000 pound flywheel or something?
1996 mustang gt
n/a
sounds like the IAC is hanging up on it clean it and the MAF . also check for vacuum leaks.
Abyssinian of AX
'02 Saleen
19.34@42.259
My '02 had this issue and hated it as well
![]() In my case, the computer "hangs" the throttle and seemed to me it was only in the higher gears (4th~5th) that did it. I had my tuner turn off this little abomination a long time ago, but don't recall an issue in the lower gears. I figure your pre-New Edge ride has the same deal, but I don't know. Going alum. fly here over the Winter, so will get even less hang than now ![]() Jazzer
Yes, that is a function controlled by the dashpot values in the EEC. A tune can correct this.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
1997 Mustang GT
Did u happen to just tune it with an SCT tune or something? My car never had the problem until I tuned it. Stock tune it ran fine, SCT tune the rpms would hang. The tuners at BAMA sent me several different tunes and helped it a little bit but I ended up just restricting the air to the IAC and its been fine ever since.
![]() PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune. |
#6 | |
Threads Similar to: Mustang takes forever for rpm's to drop
| Mustang Takes a Dip in a Pond | 06RedfireGT | The Clubhouse | 27 | March 29th, 2010 03:09 PM |
| RPM's Don't Drop Back Down After Rebuild?? | BayAreaCobra77 | 4V / SVT | 15 | March 11th, 2010 09:23 PM |
| it takes forever | graystang01 | The Clubhouse | 16 | February 24th, 2009 09:13 AM |
| Heater takes forever to produce hot air | White 89 | 5.0 Mustangs | 14 | January 24th, 2008 06:27 PM |
| Heating Takes Forever | dr.gonzo! | 5.0 Mustangs | 16 | November 21st, 2007 06:59 PM |
