#21 |
If it's a single cylinder misfire, then it's likely either a plug, plug wire, fuel injector, or possibly a coil pack (though that would effect two cylinders). You can try swapping one part at a time with another cylinder to see if the misfire moves with said part to narrow things down.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
#22 |
MM's Ginger
1998 mustang gt
walkable
anyway to figure out which cylinder?
#23 |
You said that the code was for a misfire in one of the cylinders...which cylinder was it for?
#24 |
MM's Ginger
1998 mustang gt
walkable
it doesnt say, just says
cylinder misfire detected - random cylinders |
#25 |
I had this issue once before. It turned out that coolant was leaking into the no.8 sparkplug hole. The intake is bad to leak in that area and one of the heater hoses from the firewall could easily be leaking in that area. Good luck.
#26 |
1997 Mustang GT
Go buy a spark tester, they are about $10 from any parts store. Pull one spark plug wire off of the plug, the tester takes place of the spark plug but does not go in the engine. U will need to ground the other side of the tester, best place is battery negative. Start the engine and see if it is sparking. Do this to all 8 spark plug wires, if you have spark on all 8 wires pull your plugs and look at them. If one or more of the plug wires do not spark then remove the plug wire and set up your spark checker on the coil pack where that wire was. If still no spark replace the coil pack (your ignition control module is in your PCM) the control module on our cars is rarely ever a problem. If you have spark on all wires check your fuel injectors. You can do this several ways, you can buy a noid light set or you can ghetto rig pretty much the same setup. Take a thin paper clip and insert it into the ground side of the fuel injector connection. Then start your car and put a test light on the paper clip, it should flash very fast. You could also remove all the connections on all the injectors and check them for resistance, anything above 14 ohms or so and you might have a bad injector.
![]() PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune. |
Threads Similar to: Car Bucking After 2000 rpm And Up
| Car Bucking | 40thmustanggt | 99-04 | 8 | January 4th, 2012 12:29 PM |
| Car bucking/stumbling | Blank | 2005 - 2010 | 15 | December 31st, 2010 04:46 PM |
| car is bucking | keiken | 96-98 | 5 | August 12th, 2009 01:26 AM |
| Help Bucking at low Rpms.. please? | John's_stang | 99-04 | 49 | August 19th, 2008 10:37 PM |
| car is bucking | 40thmustanggt | 99-04 | 33 | March 17th, 2008 10:09 PM |
