Mustang GT 1997 N/A
13.59@ 97.52
Need info on cylinder heads
Hello guys its been a while since i been on here well like the title says im need to know what car brand are my cylinders heads heres the vin number of the heads
9G804B- they are from a 3/8/1999 car. The reason i need to know the info its because i need to change the lifters and well my mechanic told me that those head are not of the car, i told him that my car had a full pi swap in it. Some tell that they are winsor some tell that they are of 99 gt lol so its kinda confusing any help would be gladly apreciated friends
If its off a 99 its Windsor.
MM FOBRA CLUB MEMBER #1 |
1998 Mustang GT
![]() iTrader: 2 reviews
99 and 00 mustang gts have windsor motors.so if your car has a full pi swap then you do have windsor heads, which were also on f-150's. so just go ahead and get some lifters for 99-00 mustang gt
pi swapped and dropped sn95 |
1989 LX Coupe
7.1@99mph
Lash adjusters Romeo to Windsor are the same.
As are the followers. Everything that comes off a Romeo head can go into a Windsor head. The only diff from the factory is the Windsor head came with individual cam caps, Pressed on cam gears, bigger timing cover bolts and a different valve cover bolt pattern. But if your mech is telling you that you can't use parts from one head to the other, he is wrong. Find a new Mechanic...
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
Mustang GT 1997 N/A
13.59@ 97.52
Thanks guys for the info im working in the car for the winter. Im thinking some Port and polish also dont know if it will help that much though
Traction...?
1996 GT/ 2008 GT Vert
If you port and polish properly you will notice a good difference. Removing all of that turbulence.
Threads Similar to: Need info on cylinder heads
| Cylinder head info | Stdyhand | 5.0 Mustangs | 1 | December 5th, 2011 12:13 AM |
| Cylinder head porting info (need help) | StangBanger302 | 5.0 Mustangs | 3 | September 9th, 2010 11:32 AM |
| v6 cylinder heads | Standardrift | V6 Mustangs | 13 | November 7th, 2007 01:56 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 09:55 PM |
| Cylinder Heads | thewayshemoves | 99-04 | 7 | December 26th, 2006 07:35 PM |
