rpm problem
Old December 19th, 2011, 06:49 PM   #1
97 mustang gt
ryn62188 is on a distinguished road
Exclamation
rpm problem
When ever I Rev up it takes long time for the rpm to lower. When I come to stop it idles at 1200rpm then drops to normal. I had a p1506 and replace the iac. Any ideas what could cause rpm to stay high?
Old December 19th, 2011, 08:00 PM   #2
blackout97's Avatar
97 Mustang gt
blackout97 is on a distinguished road
its normal.
Old December 19th, 2011, 08:29 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Check the vacuum line coming out of the back of the plenum for cracks.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 20th, 2011, 01:57 AM   #4
xploder17s's Avatar
xploder17s is on a distinguished road
on the back side of the plenum would cause p0171 & p0174. it would also cause a LEAN idle of 20.0 AFR... (found this out myself)
-remove iac electrical connector. the car should stall. only way to keep it running should be pedal acceleration. if it remains idling normal then the iac valve is stuck open. (self tested)
-cleaning it is damn near pointless. it fixes it for a time being before it is done permanently.(yup, done this too)
Old December 20th, 2011, 05:35 PM   #5
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
When I swapped out my plenum for a new one the vacuum tube on the back was a larger diameter on the new one. It created the same type of problem for me and I never got a code from it.
MODS IN GARAGE
NCMM ORIGINAL
Old December 20th, 2011, 05:39 PM   #6
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
^What type of plenum were you using? Just out of curiosity.
Old December 20th, 2011, 05:40 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Ford.
MODS IN GARAGE
NCMM ORIGINAL
Old December 20th, 2011, 08:07 PM   #8
BAD98GT will become famous soon enoughBAD98GT will become famous soon enough
the mustangs are notorious for the hanging idle.....it will hang for aa few seconds then drop to normal at idle....usually a vacume leak will cause it to hang a lil higher than 1200rpm...i had a vac leak and mine used to hang at 1800-2000rpm....but ever since i ported my plenum it does hang around 1200 rpm though.. what kind of mass air flow sensor do u have?
Threads Similar to: rpm problem
misfire problem, probelms, probably a problem? rewadferger 96-98 5 September 13th, 2010 12:17 PM
just solved my evap problem now a more serious problem arises I NEED HELP please sj408 96-98 5 July 16th, 2010 08:12 PM
Transmission problem??? need help diagnosing the problem... Tmac3320 99-04 19 April 13th, 2009 12:58 AM
O Jesus! Problem After Problem! mustangmanic 99-04 94 March 28th, 2008 03:36 PM
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 12:03 PM
