PI Cam Swap Without Timing Wedge? - Page 2
Old January 3rd, 2012, 07:37 AM   #21
LI98GT is on a distinguished road
I did it without the tool and took off the cover (tool didn't exist when I did it), but did not remove the chains. Marked everything up and when it came time to do the actual swap, a friend came over and held it in place while I did the swap. So basically I didn't have to worry about "retiming" it, but I was so close to doing a complete headswap, lookin back I should have done it then. I haven't had the desire to go back in there and complete the full swap.
98 GT: 02 PI cams & intake, 3:90s, TF Plenum w/70mm TB, Steeda Pulleys, Tri-Ax and STB, Catted Bassani X w/street comps welded, Densecharger TB tube, Bullitt susp, Cobra '03 Rims 13.72@101mph
http://www.cardomain.com/ride/523851/1998-ford-mustang
Old January 4th, 2012, 10:33 AM   #22
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
I finished it. I ended up not even using the tool because it kept getting in the way, biggest waste of $40 ever. The swap was pretty easy.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Threads Similar to: PI Cam Swap Without Timing Wedge?
Timing chain wedge mach1gt 4V / SVT 10 May 7th, 2011 11:54 PM
Bought the Cams...Need Timing Chain Wedge Monochrome '05 2005 - 2010 5 July 12th, 2010 11:35 AM
Timing Chain Wedge Dementions CandyredGT 2005 - 2010 8 March 14th, 2010 09:56 PM
WTF timing chain wedge? kotten148 2005 - 2010 7 March 5th, 2010 12:06 PM
Anybody got a Timing Wedge? trill gear head 2005 - 2010 7 October 12th, 2009 08:10 PM
