1997 Mustang GT
PI Cam Swap Without Timing Wedge?
Im pretty sure that tons of people have posted about this topic but Im horrible at searching
![]() Im installing my PI cams next week and wanted to know if anyone has swapped their cams without using the timing wedge. Ill buy it if I have to but I dont want to spend $30 on something just to use it once. I think I saw someone post a pic on here once before with a pair of vice grips and a pry bar or something to hold the cam gear in place? Any input is appreciated, Ill buy the tool if its the only way to go about this job without removing the timing cover, Im way to lazy to go through all of that for 10 hp
![]() PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune. |
#2 | |
2002 mustang gt
![]() iTrader: 1 reviews
You should do the full pi swap
Rock stock
1997 Mustang GT
I have the intake also, but Im not doing the heads. I plan to get a supercharger eventually.
Ill just use the tool and if it slips the worst thing Ill have to do is just end up taking off the timing cover anyway.
2002 mustang gt
I don't know about the npi engines but the passenger side cam gear has holes in it so I used screw drivers to ensure it falling, and the driver side didn't but it almost seems like there isn't enough room for the gear to fall down there, a pi head swap would be sweet, bump your compression up some to
Rock stock
my 2 cents - it does not take much cam sprocket movement before you get slack in the chain and possibly skip a tooth on the crank sprocket. If you decide to not remove the front cover, I think the most important thing will be to verify chain did not jump a tooth before starting the engine.
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears. |
#7 | |
1997 Mustang GT
1997 Pacific Green Cobra
14.80 No traction
In all honesty after having spent time on it . Take the cover off. its worth it.
Watch out for the ps pump its a bitch. dont put the bolt that sits behind the line back in. Its really easy taking the cover off and it was my first time ever.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
1997 Mustang GT
Pi Swap Cam Followers wont go back in
I bled the lash adjusters in a vice and I still cant get the followers to go back in, any of them. Should I try removing the cam and putting all of them in and then putting the cam on top?
14.80 No traction
i put my cam on top them. turned the cam in the perfect position (make sure motor is in safe mode which is 12 o clock on the keyway. Then i WALKED the 10mm cam cap bolts down with it all together and it went perfect... 15k beat on everyday miles later its still together.
1997 Mustang GT
Yea I tried that but I cant even get the cam gear on the passenger side at all. Of course I didnt have it at 12oclock, Ill try that tomorrow.
#12 | ||
MM's king of Neon's
404 - car not found
17.81@87
Also I wouldn't use bolts to force something into place, especially on a torque sensitive application with bearings. That might just be me.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
1997 Mustang GT
Are you talking about the spring compressor tool that kinda looks like a power steering pump pulley puller? I have one of those but I dont see how I could get it in there with the cam overtop.
MM's king of Neon's
404 - car not found
17.81@87
It should look something like this: (not sure if this is the 2V or 4V one)
![]() They're pretty easy. Insert your ratchet or breaker in the square hole, put the feet on the valve retainer, and the claws on the camshaft. Press down on your ratchet/breaker, and it compresses the spring, leveraging against the cam. Then your followers go in easy as can be.
1997 Mustang GT
Sweet. Did you get that from Ford or somewhere else, I kinda need one today : /
MM's king of Neon's
404 - car not found
17.81@87
I think I ended up getting mine through Tousley Ford. They saved me quite a bit on it, but it was the hard to find OTC 4v tool.
You should be able to pick up the 2v one cheap, and I know TFS sells them. Not sure if you'll be able to get your hands on it fast. It's a toss up.
1997 Mustang GT
Im gonna try to use the one that I have since I kinda need to have it finished today. Advance also sells a tool that is basically a metal bar with the feet at the end to go around the retainer. Hopefully something works.
Ford told me they wouldnt be able to get the tool in for a few weeks, which is rediculous
1997 Mustang GT
I got everything together and the car runs. Only thing is that the very last valve cover bolt on the drivers side closest to the firewall would NOT go in straight nomatter what I did. So I have to find a tap for it : / Other than having to find a tap now everything turned out fine.
1998 Mustang GT
I always used a flat head screw driver and popped them in...
Mods: Full Griggs suspension, Koni coilovers, Cobra brakes with SS lines, sub frame connectors, 3.73s, 5-speed swap, TR6's
14.80 No traction
Yeah i heard about that method i passed on doing that lol.
Threads Similar to: PI Cam Swap Without Timing Wedge?
| Timing chain wedge | mach1gt | 4V / SVT | 10 | May 7th, 2011 11:54 PM |
| Bought the Cams...Need Timing Chain Wedge | Monochrome '05 | 2005 - 2010 | 5 | July 12th, 2010 11:35 AM |
| Timing Chain Wedge Dementions | CandyredGT | 2005 - 2010 | 8 | March 14th, 2010 09:56 PM |
| WTF timing chain wedge? | kotten148 | 2005 - 2010 | 7 | March 5th, 2010 12:06 PM |
| Anybody got a Timing Wedge? | trill gear head | 2005 - 2010 | 7 | October 12th, 2009 08:10 PM |
