Always a Newb
1997 Mustang GT
pilot bearing
As I said in my last thread I am replacing clutch. The kit comes with the throw out bearing and the pilot bearing. I need to know if I have to take the flywheel off to get the pilot bearing out or does it pop out. I have tried to pry on it but I didn't want to damage any thing else so I am not sure what to do
2011 Mustang GT
12.1 @ 116
You have to take the flywheel off. Pack the hole with lithium grease and use an old wooden dowel (or something similar in diameter; I used an old clutch alignment tool) to hammer in there. Use it to create pressure behind the bearing. You'll have to pack more grease in the pilot bearing hole every time it moves to maintain pressure, but it works.
If you don't mind me asking, what brand of bearings? Also, what did you pry on it with? The inner race can't be damaged since the input shaft of the transmission is constantly rotating on it.
Mods in garage. Built suspension and gears since posted times. |
Always a Newb
1997 Mustang GT
Its a sachs clutch kit that was all i could afford around x-mas time. I was using a small screw driver
2011 Mustang GT
12.1 @ 116
Pics if you can brother. Just take that handle off the clutch alignment tool and put that dowel end into the inner race and hit it with a hammer. Easiest way to remove them. Not cleanest, but it works almost everytime.
If you can afford the extra $65 try to go hit up your local Ford stealership and get OEM TOB and Pilot bearing. The stock Ford bearings are great believe it or not.
Threads Similar to: pilot bearing
| the pilot bearing! | 95BlackStang | 99-04 | 7 | December 8th, 2011 07:29 PM |
| pilot bearing | thedriver33 | 2.3 Mustangs | 2 | October 26th, 2011 06:16 PM |
| Pilot Bearing.... | MATT02GT | 99-04 | 39 | July 12th, 2010 03:37 AM |
| is this pilot bearing ok? | PolishSasquatch | 5.0 Mustangs | 1 | July 30th, 2009 11:31 PM |
| Pilot Bearing??? | batlaxe | 5.0 Mustangs | 8 | May 17th, 2009 06:52 PM |
