Rear Brake problem
Old December 25th, 2011, 09:55 PM   #1
Borrelli49's Avatar
Borrelli49 is on a distinguished road
Rear Brake problem
Ok So i thought i needed new brakes because it was metal to metal on the previous stock rotors. but when i dug into it i noticed it had brand new pads. after i replaced the Rotors and pads this is what turned out after i test drove it. what would cause this??? if you cant see in the picture the caliper bracket is scrubbing the rotor. when i dissembled and reasembled it looked fine and not touching before i test drove. but when i went for a test drive and came back it looks like this.
Old December 25th, 2011, 10:42 PM   #2
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
looks like your slider pins are siezed. Pull them apart and regrease them and replace the boots.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old December 25th, 2011, 11:46 PM   #3
Borrelli49's Avatar
Awesome. I dont know why i didnt think of that. Ill give it a shot tomorrow. Thanks for the help
Old December 26th, 2011, 11:01 AM   #4
Borrelli49's Avatar
Just pulled it off and the sliders are free and have plenty of grease..
Old December 26th, 2011, 11:31 PM   #5
yamanx's Avatar
1998 Mustang GT
yamanx is on a distinguished road
Is the mounting bracket to the caliper rubbing on the rotor??
Mods: Full Griggs suspension, Koni coilovers, Cobra brakes with SS lines, sub frame connectors, 3.73s, 5-speed swap, TR6's
Old December 27th, 2011, 07:34 AM   #6
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Hard to tell from pic angle, but would look to a possible bent caliper braket. If it is bent, it will not hold the caliper "square" to the rotor and hence make contact.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old December 27th, 2011, 11:27 AM   #7
Borrelli49's Avatar
Yes the bracket is scrubbing, but i noticed it only hits when i pull with the play in the axle. So i took my diamond bit grinder and ground off about an 1/8" on each side of the bracket and problem solved!
Threads Similar to: Rear Brake problem
rear brake problem Giggle Juz 99-04 3 March 18th, 2010 08:44 PM
Serious Rear Brake Problem Pittbull 99-04 31 November 8th, 2009 06:11 AM
Brake light switch problem after upgrading brake booster black88 5.0 Mustangs 2 January 20th, 2008 11:41 PM
Rear brake pad install problem 2006greyGT 2005 - 2010 6 January 13th, 2008 04:17 AM
having a problem depressing rear brake piston blue6er99 General Tech 5 June 19th, 2006 08:12 PM
