99 GT Engine Swap
Hello, I have a question hoping to get an answer. Is there a difference between the 99 mustang gt 4.6 and a 96 mustang gt 4.6 when it comes to the engine? Advantages/Disadvantages?
Thanks |
2000 GT
![]() iTrader: 3 reviews
I know the 99 has PI heads and is rated for 260hp. Not sure of the 96 power but I know it is lower on tq as well.
8.7 1/8 mile
The main advantage is the head/intake designs are much better on the 99-04 2v mustangs. Therefore, there is potential for more power with them.
Pi is 99-04 pi is performance improved it s basically a direct swap for all 96-04 mustang gts do the swap you'll love it
MM FOBRA CLUB MEMBER #1 |
1998 Mustang GT
![]() iTrader: 2 reviews
the 96 only have like 215 hp compared to the 240 or something of the 99 and up. the 99 and ups are better like everyone is saying. the heads and intake flow better and will yeild more gains. they both are interchangeable as far as putting them in either car with either tranny
pi swapped and dropped sn95 |
#7 | |
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
2002 mustang gt
![]() iTrader: 1 reviews
Are you wanting to swap the 96 into the 99? Or vise versa
Rock stock
MM's king of Neon's
404 - car not found
17.81@87
There are minor differences, but both will bolt up into your car.
The 96 GT is a Romeo block, remote coil, NPI motor. The 99 GT is a Windsor block, COP, PI motor. You will have different intake manifolds, heads, flywheels, blocks, timing covers, valve covers, and possible tensioners. But that's not to say they're not interchangable. As long as you basically get the 99 as a liftout, you won't have to change anything.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
So I can get a 99 gt and put it right in my 96? I am assuming that I can use the same wiring harness and computer?
You'll want to run your wiring harness and computer. It's pretty direct swap
That simple huh?
Dont' the 99 gt engines have a different set up when it comes to the coil? The 96 has two 4 pack coils on each side on the front of the engine and I read that the 99's have coil over packs. How do I deal with that when making a swap from a 96 4.6 to a 99 4.6? Its going in a 96 gt 5sp
Just swap your coils over to that engine.... like I said just swap engines no electronics
1989 LX Coupe
7.1@99mph
^ Ppl make this harder than what it is huh. lol.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
1997 Pacific Green Cobra
14.80 No traction
you can't sawp auto transmissions easily if you have an auto. you have to repin the transmission wire harness and change the solinoids if you dont use the ecu from the doner car.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
I do have a 5spd. The main rean why I was looking to do the swap is bc I think my borla stingers that I have on my 96 4.6 will gain a better deeper throaty sound with a 99 4.6
If I just switch the heads and intake out, will I need any additional parts like timing chain and etc to switch the heads or are they a direct swap as well as the intake manifold?
There are thousands of threads on this not onky in this forum but every forum. Yes you can just change the heads intake and cams
Threads Similar to: 99 GT Engine Swap
| Engine swap? Can you swap a 99v6 for a 98 GT engine? | Bobby00000 | V6 Mustangs | 28 | January 1st, 2012 11:39 PM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
