Gearing up to buy A 96-98 Cobra. Advice is needed.
Old December 30th, 2011, 07:53 PM   #1
1989 mustang GT
12.5
dewwy7272 is on a distinguished road
Cool
I need any info you guys could give on these particular cars. My budget is only 6000. What mods should I want the car to have. Most of the ones I see in my price range are normally between 95000 and over in milage. How concerned should I be about this.What should I avoid with these cars as i start to look at them. I live in a great area and see several cars within budget.
Old December 30th, 2011, 09:21 PM   #2
1998 Mustang GT
MustGT98allday will become famous soon enough
if i was you looking for a cobra I would search for the one that is bone stock. that most likely means an older person or someone decent had it and hopefully didnt beat the hell out of it. 95,000 isnt bad but at that mileage make sure the price is right. just make sure the tranny shifts smoothly and the engine runs mint with no knocks or ticks and you should be good to go
pi swapped and dropped sn95
Old December 31st, 2011, 12:55 AM   #3
00MustangGtPremium's Avatar
2000 Mustang Gt
no clue
00MustangGtPremium is on a distinguished road
Get a cai and exhaust. Improve flow in and out.
Just because your cars loud doesnt mean its fast
Old December 31st, 2011, 01:14 AM   #4
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Gears like 4.10 and if you don't fear the gear some 4.30's. If you plan on supercharging it then 3.73 would work too.
And obviously check all the other stuff like O2 sensors , plug wires and boots ect before modding things.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old December 31st, 2011, 05:23 AM   #5
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
Do a compression test before you buy from anyone. I would look for one with bolt-ons at the most. Make sure when you test drive it to get out of the neighborhood an go through all 5 gears. Stick it in 4th or 5th at a low speed, like 35 or below and give it gas to see if the clutch slips and will be needing replacing soon. Look the car over good, and look to see if anything has any wet-ness under the hood. Make sure to get it to operating temp and see what it sounds like then.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old December 31st, 2011, 09:17 AM   #6
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
with those miles in mind, be ready to do all regualr maintenance things associated with a 100K car. bushings all around, fluid changes in EVERYTHING (trans, axle, motor, coolant...the works) like somebody said before, make sure the clutch is stong and if you have the ability, do a compression check on it too. other than that, Mustangs tend to be decent running/reliable cars as long as you dont skip out on the regular preventative maintenance.
as far as 1st mods go, do FLSFC's, some lower control arms, and some gears (4.10's or 4.30's)
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old December 31st, 2011, 01:13 PM   #7
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Gears for sure, that's not that many miles
Rock stock
Old December 31st, 2011, 06:58 PM   #8
1989 mustang GT
12.5
That is good to hear, because most of the ones I see are at least 90000+. Im really starting to get excited about getting a new Stang. I know where most are on the western side of the good ole USA.
Old January 12th, 2012, 07:38 PM   #9
1989 mustang GT
12.5
Thanks guys! you've been a ton of help. This is a great site.
Old January 12th, 2012, 10:31 PM   #10
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
The only mods id ever do to a sn95 cobra would be exhaust, CAI, 3.73's and a tune. I wouldn't want to mess around with a cobra. A GT is a different story though. IMO that is.
Old January 12th, 2012, 11:04 PM   #11
p4ndiamond's Avatar
14.80 No traction
sub frames are a must.
Old January 12th, 2012, 11:12 PM   #12
Traction...?
1996 GT's Avatar
^Oh plus that also.
Old January 13th, 2012, 07:26 PM   #13
p4ndiamond's Avatar
14.80 No traction
lol ya. i have yet to get mine.. i need to get on that.
Old January 15th, 2012, 06:45 PM   #14
99Ls1fever's Avatar
2ndPlaceSetofSteakKnives
99Ls1fever is an unknown quantity at this point
I wouldnt be worried about the miles at all
I bought mine with 170k miles on it and turboed it. Havent had any problems yet except... I took it to the track and blow the tranny, had to do a full tune up, rebuilt the tru lock and did full bearings when I put new ring and pinon in. Bought it for $2500 bucks after someone put it in a ditch and broke the steering rack.
03' Cobra | 3.4 Whipple | SRA Swap |
99' SS | Forged 347 | YSI 16psi | 12 Bolt |
96' Cobra | On3 FF Kit | T45 Source Tranny | 3.55's |
91' GT | GT40 Intake | CAI | Headers |
www.fquick.com/99Ls1fever
Threads Similar to: Gearing up to buy A 96-98 Cobra. Advice is needed.
advice needed. Genevieve! The Clubhouse 28 October 20th, 2011 11:58 AM
Possible new buy, advice needed firestoned 5.0 Mustangs 1 October 9th, 2010 03:17 PM
Advice Needed !!! -FoxBoy- 5.0 Mustangs 20 February 7th, 2010 06:30 PM
some advice is needed. jat 5.0 Mustangs 5 January 7th, 2010 09:16 PM
advice needed heelsbball Visual 10 January 9th, 2009 01:38 PM
