Speedometer
Old December 30th, 2011, 08:39 PM   #1
Jhoward93's Avatar
1997 Mustang GT
Jhoward93 is on a distinguished road
Speedometer
Well had my car for awhile now an the speedometer has never worked neither does the odometer an now i want to attempt to fix them. I noticed the what i guess was the speed sensor was unplugged so i plugged it in an car wouldnt go over about 40mph so is it that the sensor could be bad causing all that or something else? Any help would be appreciated.
A few racing videos.
http://www.youtube.com/user/MrJhoward93?feature=guide
Old December 31st, 2011, 05:19 AM   #2
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
First do you have an auto or manual? Look towards the tail shaft of the transmission, there will be a cable that goes into it. 2 bolts hold it in, when you pull it our there will be a gear on the end of the cable, held on by a snap ring IIRC, chances are if you speedo and odo arent working the teeth are worn off of this gear. replace it. When you spin it (by hand) you should feel 'pulses' in the cable, thats what your cluster uses to determine speed and mileage. if you dont feel pulses you may need to replace the whole cable, or it may not be hooked up to the cluster. Usually the gears are the first problem though. With your 373's your speedo will be off though, and your Odo will read miles faster, as the gear ratio for the cable is set for whatever stock gears came in your car. You can get different gears from steeda for differnet gear sets. But it will never be dead-on. The only way to make it dead on in a 96-98 is to get a dallasmustang.com Speedcal.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old January 1st, 2012, 12:47 AM   #3
Jhoward93's Avatar
1997 Mustang GT
I have a manual
Old March 22nd, 2012, 11:31 PM   #4
Jhoward93's Avatar
1997 Mustang GT
I know this kinda a old thread but bein tryin get this fixed got pulled over for speeding so kinda need a spedo I have looked at the transmission i dont have a cable or anyhting going into the transmission all i have is 2 sensors an one of them is the transmission speed sensor an when i plug it in the speedo still doesnt work an the car wont go over 40 so could it be that the sensor is bad? Kinda lost on what to do any help would be great. An the transmission I believe is a tr3650
Old March 23rd, 2012, 08:39 AM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I have a friend who's in the same situation.
I think a big problem might be the wrong style transmission. I don't think the TR3650 started showing up until the new edges, which used the reluctor wheel type speed sensor.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old March 23rd, 2012, 10:00 AM   #6
Jhoward93's Avatar
1997 Mustang GT
Mine has the plug on the wiring harness for the sensor just when I hook it up it doesn't work.
Old March 23rd, 2012, 10:15 AM   #7
2v power
xandraxal's Avatar
96 Mustang GT
xandraxal is on a distinguished road
Have you tried replacing the gears in the dash panel?
Old March 23rd, 2012, 11:44 AM   #8
Jhoward93's Avatar
1997 Mustang GT
No I haven't but if those are bad would it cause my car not to go over 40 cause the problem I'm having I think is coming from the speed sensor cause if I plug it in the car won't go over 40 an the spedo still won't work but I just don't wanna go buy one an that not fix the problem.
Old March 23rd, 2012, 12:09 PM   #9
2v power
xandraxal's Avatar
96 Mustang GT
The Speedo and odometer can be fixed, most likely, by replacing the little neoprene gears in the gauge cluster itself. As far as car not going over 40, wont fix that. Sounds like 2 separate problems
Old March 23rd, 2012, 12:11 PM   #10
2v power
xandraxal's Avatar
96 Mustang GT
Are you saying that car doesnt go faster than 40mph, or the speedometer wont read any higher than 40?
Old March 25th, 2012, 04:45 PM   #11
jrcurtis00 is on a distinguished road
I had the speedo/odometer problem also. Not the 40mph problem. But I replaced the gears in the instrument cluster. Takes about 30 mins. The gears are made of a plastic type material will probably be disintergrated. The transmission should be a t45.
Old March 25th, 2012, 07:17 PM   #12
Jhoward93's Avatar
1997 Mustang GT
The cluster never works but when I plug in the speed sensor it still doesn't Work an the car won't go over 40 so I just leave it unplugged an someone told me that when a speed sensor goes out it will cause that to happen like some kind of safety feature does anyone know if that's true?
Threads Similar to: Speedometer
Speedometer? 91Mustang GT 5.0 Mustangs 10 January 30th, 2011 03:53 PM
99 v6 speedometer raj 99-04 11 October 19th, 2010 04:28 PM
speedometer is off mustang98_08 99-04 9 April 5th, 2009 01:56 AM
Speedometer djh1286 V6 Mustangs 12 January 5th, 2008 02:09 AM
Speedometer Arhilion 96-98 8 May 23rd, 2007 07:36 AM
