1997 Mustang GT
None yet...
Changed valve cover gaskets... have a question about the RTV
changed valve cover gaskets, did the whole RTV on the two spots where neccessary, i'm wondering, how long would be ok until i can test drive it to see if everything is buttoned up right. its already been a few hours.
95 GT - nothing stock on her R.I.P. 97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot. |
1996 mustang GT
![]() iTrader: 1 reviews
You should let the rtv be dry for about four hours before putting the coolant then about 24 hours before turning it on. That's just a recommendation.
1997 Mustang GT
None yet...
coolant?? i didn't drain any coolant, i just replaced my valve cover gaskets and also painted them blue! i'm really excited and i'm curious as to how its going to run....
1996 mustang GT
Lol my bad I understood intake for some reason. Don't blame the alcohol
1997 Mustang GT
None yet...
haha, thats always fun! lol
Traction...?
1996 GT/ 2008 GT Vert
Let it sit over night, if you rush it while its still setting you're going to regret it and have to do it all over again. IMO that is. I did a water pump with the RTV also and started it up 30 minutes later.
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
Is the RTV actually used to seal up the valve covers (never seen them on a 97 Mustang)? When I did my wife's valve cover, it had a gasket and I used RTV in 3 spots. But that was just to hold the gasket on while getting it put in place. I drove it right after I tightened everything up since it wasn't for sealing.
Traction...?
You don't need it at all. But there are four recommended spots to keep it in place and to prevent a common leak.
1997 Pacific Green Cobra
14.80 No traction
Its there to hold the gasket. its a spot that is between the head valve covers and front cover. Mostly so oil will not seep out. but it will be fine.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
Threads Similar to: Changed valve cover gaskets... have a question about the RTV
| valve cover gaskets... bbk | toolstang | 99-04 | 12 | June 24th, 2011 01:19 PM |
| valve cover gaskets | disturbdgt | 99-04 | 10 | April 23rd, 2010 12:54 PM |
| valve cover gaskets | cali 5.0 | 99-04 | 5 | June 23rd, 2008 07:20 PM |
| Valve Cover Gaskets | black88 | 5.0 Mustangs | 5 | December 12th, 2007 06:02 PM |
| changed valve cover gasket | caintcatchmyGT | 96-98 | 1 | November 4th, 2007 01:32 PM |
