Testing the evap flow sensor (p1443 code)
Old January 2nd, 2012, 12:47 AM   #1
Vect0rmask's Avatar
1996 Mustang GT Convt.
Vect0rmask is on a distinguished road
Send a message via Yahoo to Vect0rmask
Hey guys, I pulled up some info when I was working on my car last week and I figured I'd share it with you. The code I had was P1443.
This is your EVAP flow sensor:
Here in the engine compartment, I circled it:
It is connected to the vacuum line from the back of the throttle body/plenum area to the sensor, then down to the charcoal canister.
Here are the pins on it, labeled A,B, and C:
Before you test the sensor, check for vacuum leaks in the system. Unplug the connector and pull the sensor out, then let it cool to room temp.
Pin A:Ground
Pin B: Power (reference voltage I think)
Pin C: Signal
Use a ohmmeter to measure the resistances between the following pins:
A to C: Should read more than 25.5 Ohms.
B to C: Should read between 25.65-28.35 Ohms.
A to B: Should read 130 Ohms or less.
If anyone finds something wrong in here just let me know and I'll fix it.
Threads Similar to: Testing the evap flow sensor (p1443 code)
The dreaded P1443 EVAP Code sheltonfilms General Tech 0 July 8th, 2011 03:07 PM
P1443 Evap code? Cycleeric 96-98 7 October 23rd, 2010 10:17 PM
CEL Code P1443 MustangMo V6 Mustangs 8 August 7th, 2008 04:40 AM
Trouble Code P1443 Pressure Sensor? Tlord18 V6 Mustangs 6 July 17th, 2008 01:22 PM
p1443 where is the evap emissions valve? born2mustang V6 Mustangs 13 August 12th, 2007 05:42 PM
