1997 Pacific Green Cobra
14.80 No traction
WOT Short Term Fuel Trim
Been doing some data logging . and it seems at wide open throttle the car is requesting a value of 20.1 short term fuel trip at around 5k RPM. is there any way to richen that up some. This is on P.I intake/cam swapped motor.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " Last edited by p4ndiamond; January 2nd, 2012 at 03:11 PM. |
96 Mustang Gt
![]() iTrader: 1 reviews
Want to tune mine? Lol
14.80 No traction
heres the specs on it and what its requesting right now.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
STFT's aren't reliable data to look at when in open loop (WOT). You can use STFT's to tune in closed loop, but you'll need to use a WBO2 to do your WOT tuning.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
14.80 No traction
Ya just got my wideband ordered . should be here friday.can't wait.
Rollin' 18/ pushin' 2
If my car was running that lean I would shut it down.
The STFT's are just that, trims. He isn't seeing a 20:1 AFR.
14.80 No traction
Yeah. im surprised that it trims that hard . Even when i richen the MAF up top its still the same. Once i get my wide band in i will beable to do everything properly of course .just still surprised that stomping in the mine field shows no effect. I would assume the PI swap (intake and cams ) would make things leaner vs rich meaning i have to add fuel .
Ok. Educate me. What is all this jibberish about. I have no tuning experience other than adjusting screws on carburators to run rich or lean. ![]() I leave all my tuning to the experts.
#10 | |
14.80 No traction
I think i explained that right lol.
96 Mustang Gt
Why is it saying that much hp and torque?
#12 | |
Short term fuel trims are the immediate adjustments made by the EEC during closed-loop using the narrowband O2 sensors to achieve the commanded AFR. Long term fuel trims are adjustments made by the EEC using the trends seen from the STFT's. There is WAY more to this, but that is about as basic as I can make it.
14.80 No traction
#14 | |
14.80 No traction
96 Mustang Gt
Ha. There is no way you make that much unless you added something and didnt tell us about it. Lol
If the MAF transfer function isn't correct (which effects the load calculation) and/or the MBT table isn't correct, it will throw off the torque calculation. Horsepower is derived directly from that calculation and engine rpm.
96 Mustang Gt
Ah. Got ya.
14.80 No traction
Yeah this not dyno tune lol but my other engine will dyno probably about that or much more.
14.80 No traction
Do you happen to know if we can use our cars EGR monitor wires as a wide band port like on the EEC-IV cars . i planned to do that also if possible
#20 | |
I use XCal2's to tune my cars, so my widebands just plug into the analog port on the handhelds.
Threads Similar to: WOT Short Term Fuel Trim
| P0173 - Fuel trim Malfunction Bank2 | Starfish_Ninny | 99-04 | 5 | May 27th, 2011 02:37 PM |
| How to read short term fuel trim | KevinJ99GT | 99-04 | 5 | May 20th, 2010 06:42 PM |
| p1150 fuel trim at level dtc??? need answers! | o2gtstang | 99-04 | 7 | September 20th, 2009 12:37 PM |
| Long and Short term fuel trims | JASonic | 99-04 | 11 | March 13th, 2009 07:31 PM |
| Sniper Recon fuel trim fix... | cliffyk | 99-04 | 4 | June 18th, 2008 11:50 AM |
