Overheating Issue!!! Need Help
Old January 3rd, 2012, 10:13 AM   #1
1998 mustang gt
0.00
9848mustanggt is on a distinguished road
Angry
hi everyone thanks in advance for any help!!! i have a fully built 98 gt.. car is overheating when either running it at idle to long or if getting on it or if just cruising. some details are d1sc procharger 12lbs of boost,3 core intercooler, pi swap, shm cams, dss racing block, forged bottom end, edelbrock manifold and hi flow water pump, fluidyne radiator, full exhaust. the fan is hardwired to run on high at all times and is working fine, coolant system is in mint condition, have beat my head against the wall trying to figure this out.. also when trying to use the ac its even worse!!! have gone through that system as well and it is perfect!!! any help would be very appreciated!!! thanks guys! great forum!!!
Old January 3rd, 2012, 11:12 AM   #2
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
I'm going to start with the obvious, how much coolant is left in your tank?
Old January 3rd, 2012, 11:53 AM   #3
1996 Mustang GT Vert
Blower Head is on a distinguished road
Are you going by the gauge, or do you have some other indicators? If you are going by the gauge you need to check by installing a mechanical gauge or using an Ir thermometer.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old January 3rd, 2012, 12:30 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Start at the begining, how's your thermostat working?
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 3rd, 2012, 12:59 PM   #5
1998 mustang gt
0.00
overheating issue
the coolant jug is full, never gets low. the gauge is right on i have checked with ir and with a mechanical as well as with my snap on scanner, all are within a couple of degrees. t stat is opening properly
Old January 3rd, 2012, 01:19 PM   #6
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Check the thermostat . Check the coolant level. Also you may need to change the low speed fan setting in your tune. I had this issue and i set it to come on at 185 on a 192 thermostat. it stays between 190-194 at all times. Also look into a mark VIII fan .
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old January 3rd, 2012, 01:30 PM   #7
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
did it start running hot recently or has it been that way since you bought it? It seems you have made alot of upgrades to the cooling system already.
MODS IN GARAGE
NCMM ORIGINAL
Old January 3rd, 2012, 01:45 PM   #8
1998 mustang gt
0.00
i did check the t stat and the fan is hard wired to run on high at all times..
Old January 3rd, 2012, 01:47 PM   #9
1998 mustang gt
0.00
it has run hot ever since the procharger was installed and tuned.. i had the shop go back over the tune and they are saying it is correct and should not be affecting the temp..
Old January 3rd, 2012, 04:07 PM   #10
p4ndiamond's Avatar
14.80 No traction
hows the oil pressure.
Old January 3rd, 2012, 05:11 PM   #11
1998 mustang gt
0.00
oil pressure is in spec, checked with my gauge and a mechanical gauge
Old January 3rd, 2012, 06:13 PM   #12
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Are you going by the stock guage or an aftermarket? Are there any other symptoms of the car overheating or is it just on the guage?
The reason I ask is the stock guages are not very accurate. Most people who see overheating problems on the guage but don't have any actual symptoms find they really don't have a problem at all once they put in a aftermarket temp guage.
The 96' cars all had actual cooling problems but Ford corrected the problem for 97+
MODS IN GARAGE
NCMM ORIGINAL
Old January 4th, 2012, 08:54 AM   #13
1998 mustang gt
0.00
yes i have checked with a ir temp gun and my snap on scanner. temp is getting to hot
Old January 4th, 2012, 09:44 AM   #14
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Well I see why you are stumped then. Looks like you have covered all the bases and are still having problems. Unless your high flow water pump is screwing up or your new radiator isnt flowing right I dont understand why your having problems either.
MODS IN GARAGE
NCMM ORIGINAL
Old January 4th, 2012, 09:54 AM   #15
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
What temps are you actually seeing?
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old January 4th, 2012, 10:20 AM   #16
1998 mustang gt
0.00
yeah it is crazy, i have tested the radiator and the cooling system and it all checks out. have very good flow
Old January 4th, 2012, 10:22 AM   #17
1998 mustang gt
0.00
its been awhile since i checked it, i havent driven it much, but if memory serves it was getting up to 230 and still rising
Old January 4th, 2012, 10:23 AM   #18
1998 mustang gt
0.00
i am leaning towards the procharger creating to much heat, have seen alot of people who have the same issues
Old January 4th, 2012, 10:31 AM   #19
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
Did you flush your coolant whenever the Procharger was installed? Theres a chance that you might have an air pocket somewhere.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old January 4th, 2012, 10:36 AM   #20
Tang Stang's Avatar
What have you done to verify that the tstat is opening properly?
Threads Similar to: Overheating Issue!!! Need Help
Overheating issue mgiara 2005 - 2010 17 December 23rd, 2011 10:57 PM
Overheating?? PurpleStang96 96-98 2 August 20th, 2011 08:41 PM
Intake manifold issue or head issue? sledgehammer357 All Other Vehicles 2 July 20th, 2011 01:58 AM
98 GT overheating tvllgeorge 96-98 7 December 9th, 2010 10:17 PM
Keeps overheating please help! Moeski 96-98 8 August 22nd, 2010 06:17 PM
