1/2 PI Swap Guys
LinkBack (1) Thread Tools
Old January 3rd, 2012, 02:12 PM   1 links from elsewhere to this Post. Click to view. #1
96 Mustang Gt
FLEX4.6 is on a distinguished road
1/2 PI Swap Guys
What kind of times are yall running at the track? And have any of yall dynoed the after with it? Also, how much did you spend on it? And do you feel it was worth it doing only half? Why did you only do half? Thanks
Old January 3rd, 2012, 03:12 PM   #2
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
What do you mean 1/2 PI swap
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old January 3rd, 2012, 03:48 PM   #3
96 Mustang Gt
Just intake and cams.
Old January 3rd, 2012, 04:03 PM   #4
p4ndiamond's Avatar
14.80 No traction
Gonna cost allot more for the 10hp gain. i personally don't find them worth it over the intake and cams. but if you are up to the work its cool to do .
Old January 3rd, 2012, 04:18 PM   #5
96 Mustang Gt
What part are you talking about for 10 hp gain?
Old January 3rd, 2012, 08:36 PM   #6
96 Mustang Gt
So is it true that the heads only yield around 10-15 extra hp. I have been reading about it and have not found any solid proof. I have seen full pi swaps pull out low 14s high 13s. I want to see what your car runs since you got the kinks worked out. Would actualy like to have a friendly run one night to see how much more your parts helped over my k&n and exhaust. That way I can truly make a decision
Old January 3rd, 2012, 09:31 PM   #7
1996 mustang GT
projectGT is on a distinguished road
K&n over pi swap?
Old January 3rd, 2012, 09:33 PM   #8
96 Mustang Gt
He only has cam and intake...
Old January 3rd, 2012, 09:56 PM   #9
wveil3v's Avatar
98 Mustang GT
wveil3v is on a distinguished road
Just got done with the PI intake swap yesterday and got into it some today. I can tell you I don't need to spend the money on dyno yet to know it's a worthy mod. I spent the last month researching this because of the slight gasket mismatch and mine is my dd. I bought my 98gt used with 3.73 gears, jlt 4" cai and flowmaster catback with stock hpipe. I think it already had some cams because the npi heads and intake were replaced or and worked and it's got a nice lopey idle. The intake it had was the new npi with alum crossover and looked just like a PI with the blue Oring plenum gasket already installed. It also has Oring gaskets chaneled in the plastic throughout all intake ports coolant ports. It's a nice piece they produced after the settlement and I was not gungho to replace it with the PI, but so far I can say it's a definite nice SOTP improvement. I need a catted HPipe now, which is gonna be hard to find for a decent price but I can wait, or I have material to get it made up if price is right.
Today I started off easy in 1st, shifted to 2nd gear and took it up to 5200rpm and she broke loose early without stabbing it that hard, so it never acted like that before but I am not beating on this car because the motor is very solid and it's generally in great shape. I got the "BlueOvalChips" PI swap kit and followed his install instructions where he uses modified bolts for temp mounting studs to align the intake on the gasket so it doesn't move or slide, so I hope it lasts, so far so good.
Didn't bother with pics because there are tons already and quite frankly I was so involved and up against the clock in my condo parkinglot that I just got it done 2hrs before the winter blast of air came in yesterday.. (Whew)
Hope this helps some. I will post pics of the newold npi intake which is for sale and my newold 98gt to put in my avitar to replace my 06 gt which was sold awhile back.
98gt, pi intake, jlt cai, flowmasters, black bullits, hurst comp-plus, custom hpipe, eibach sportlines, 373gears
Old January 3rd, 2012, 10:16 PM   #10
p4ndiamond's Avatar
14.80 No traction
i dont have any of my kinks worked out so to speak. i've just made it faster. but im going for precession .
Old January 3rd, 2012, 10:20 PM   #11
p4ndiamond's Avatar
14.80 No traction
My cams and intake felt a big difference . but being a 4r70w i need all the tuning i can get and Jmod ect. Heads are not totaly worth it but do make good CHP. cams and intake made a big difference in how long the car pulls. But my car is still much slower than it should be. its all in the tune now. This motor setup is just my tuning ginny pig until im done the other engine. I will need all the tuning in the world to make that work right lol. So im learning now to prepare for it. And workign on the chassis and body for autox purposes more so than the 1320 .
Old January 3rd, 2012, 10:27 PM   #12
96 Mustang Gt
I have the 5spd. You had big kinks for the time you ran. Must have been real bad when you ran tylers old gt. i wan to see you get it all worked out and see what time you can pull.
Old January 3rd, 2012, 10:43 PM   #13
p4ndiamond's Avatar
14.80 No traction
Yeah that night at the track my car was even driving like ass lol . i had a bad crank sesnor and it was super humid. Had rev limiter issues with the trans and could not go faster than 80 mph in 3rd cause it forced overrive at that speed. On top that i had bad struts , i had my rebound in the back set wrong and i only had 3 hours of sleep . Lol . i had quite a few issues.
Old January 4th, 2012, 01:25 AM   #14
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
Id rather just swap in a low mileage PI motor then do a PI head/cam swap
410rwhp 520rwtq @ 12.9 psi
Old January 4th, 2012, 01:52 AM   #15
p4ndiamond's Avatar
14.80 No traction
Lol says sharkey who still got a 5.4 lol . I could have had a 5.4 dohc but i did not want to go through the extra work of fitting it in haha
Old January 4th, 2012, 09:43 AM   #16
1996 mustang gt
13.07@104.66
JK7208 is on a distinguished road
after full PI head swap (PI cams) I dynoed at 278rwhp/295rwtq
1996 GT 5-SPEED
PI SWAP Trick Flow 75mm TB/PL
BBK CAI, UDP, Mac Longtubes and offroad Prochamber SCT tuner
Seeda Triax Short Throw Shifter
3.73 Ford Racing gears
278rwhp/295rwtq
Old January 4th, 2012, 10:50 AM   #17
Ruffellbaker's Avatar
1997 Mustang GT
Ruffellbaker is on a distinguished road
I did the Pi Cam swap last night and just from driving it around normally I can tell a difference. I havent beaten on it at all but I can already tell that it drives much smoother and pulls better after 2k. Still need to find an Intake Manifold for a decent price tho.
PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune.
Old January 4th, 2012, 09:44 PM   #18
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
You should just swap the aengine in.
MM FOBRA CLUB MEMBER #1
Old January 4th, 2012, 10:07 PM   #19
p4ndiamond's Avatar
14.80 No traction
lol thats what im doing haha. getting the most out my PI swap tho. it was fun while it lasted
Old May 5th, 2012, 10:27 PM   #20
1998 Mustang GT
jstang98 is on a distinguished road
id like to hear some debate over pi cam/intake swap vs. full pi swap...and why would anyone rather want the pi motor over the swap the same parts with a bump in comprssion...a pi swapped npi has to be better then a pi motor (for NA purposes)
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/244516-1-2-pi-swap-guys.html
Thread question for pi swap guys | Forums at Modded Mustangs | BoardReader This thread Refback April 22nd, 2012 06:07 AM
Threads Similar to: 1/2 PI Swap Guys
For all you guys looking for heads to do PI swap 98Thunder 96-98 0 July 16th, 2010 10:52 AM
For The Windstar-Swap Guys One Bad Sixxx V6 Mustangs 42 March 16th, 2010 06:45 PM
YOU p.i SWAP GUYS IN HERE Silver281gt 96-98 14 April 1st, 2009 03:28 PM
351w swap guys, need your help! built351w 5.0 Mustangs 11 June 17th, 2008 02:19 PM
98 guys looking at the PI cam and intake swap Darrin 96-98 3 February 11th, 2008 04:33 PM
