1997 cobra
Baseline Suspension
i'm getting ready to do the rear suspension on my 97 cobra and i have heard alot of good things about baseline suspension. i'm setting the car up for drag racing and want it to hook. anyone use this suspension and what parts work best. i'm using a coilover setup so i need help with spring rate and shocks. open to all suggestions about the best company to use.[IMG]
[/IMG]
Rollin' 18/ pushin' 2
I have never heard of them. Are you still going to street drive the car or is it going to be strictly a track car?
Granny Shifter
Paging MustangMatt96GT
1997 cobra
i'm gonna drive it to the track. my main purpose is to race the car. check them out at baselinesuspension.com .
1997 Mustang GT
N/A
Maximum Motorsports can be your one-stop-shop for suspension. Americanmuscle.com has alot of good deals on killer suspension components too.
Proud American
Kevin at Baseline is the man!
I have the heavy duty Prolaunch kit. Very top notch stuff... I didnt opt for the coil over route, but sense you have, you can use one of his lower control arms. Setting up the geometery does depend on your springs. What is the weight of your car? Whos coil over setup did you use?
1997 cobra
i don't have the coilover setup yet but i'm looking for opinions. i have just heard that coilovers are the best for drag racing. what shocks should i use? i was told strange shocks and springs are the best.
Proud American
Depending on what the weight of you car is I can recommend spring rates for you. But strange shocks do quite well, it's what I have under my car.
1997 cobra
not sure what a 97 cobra weighs. i dont want to gut the car so everything is still in place like it came from ford.
!FACEPLATED!
if your keeping the stock style rear suspension, you can get just as good of results with coil over springs in the stock location. The factory location of the shocks isnt the best design to get the full benefit of COs for drag. Just experiences I have had. As far as baseline, I run there relocated uppers and love the difference they made.
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#11 | |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
start with tires. Almost any suspension setup will hook like crazy with the right tires. I would refrain from revamping your rear suspension especially for a relocated solid heim end suspension without seeing how your car performs with a conventional setup. Relocated suspension is pretty much a waste of money for 99% of mustangs. This is coming from someone who has run relocated uppers, lowers, and stock location control arm setups with every type of bushing on the market. I currently run team z uppers which are basically the same as baseline but a lot stronger and made with better materials.
#13 | |
Proud American
The most useful part about a relocated upper and solid bushings is the consistancy the suspension ends up having.
1997 cobra
what do you think of the s&w frame connectors. a friend of mine is a chassis/engine builder and said s&w makes the best stuff on the market. wondering if anyone used these.
#15 | |
!FACEPLATED!
Sent from my HTC Wildfire using AutoGuide App
Proud American
S&W race cars are great as is quartermax.
A lot of there stuff isn't specifically built for a chassis and is universal. Some stuff is built perfect though.
Threads Similar to: Baseline Suspension
| baseline dyno run | SadleUp | 2011+ | 14 | July 29th, 2011 05:43 PM |
| Question For Those With Baseline UCA and/or LCA | andrewskaggs | 99-04 | 6 | May 9th, 2011 04:23 PM |
| Baseline dyno run | scooter3 | 99-04 | 18 | February 28th, 2011 07:23 PM |
| Baseline suspension | 02gtmustang | 99-04 | 20 | December 21st, 2010 07:47 PM |
| Anyone running Baseline suspension pieces? | C MY 4D | 4V / SVT | 9 | September 25th, 2008 01:04 AM |
