Problems Installing T45
Old January 3rd, 2012, 10:29 PM   #1
'92 5.0 & '98 Mustang GT
Rich2279 is on a distinguished road
Well, I installed the '03 Explorer aluminum 4.6L in my '98. Slid right into place. Problem is with the T45 trans. I can not get it to slide in there. Spending way too much time on this. I am at the point where I'm considering pulling the motor back out, attaching the trans, and then installing them together. Anyone have ideas? I've been fighting this trans the past 3 days (few hours each day) trying to slide it in.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
http://www.cardomain.com/ride/394916...ng-gt-coupe-2d
Old January 3rd, 2012, 10:56 PM   #2
war1ock's Avatar
1997 Mustang GT
N/A
war1ock is on a distinguished road
Im assuming its going into a already manual car not an original automatic? Do you mean like you just cant get it into the right placement to bolt it up? Maybe try taking the crossmember out. Wouldnt see what would cause the problem.
Originally Posted by Boercker View Post
ram it in the whole and see what happens (my philosophy)
Originally Posted by BakerFX4 View Post
Im more a meth kinda guy. Primarily on the weekends.
1997 GT. K&N Filter, Smoked Angel Eye Headlights, Sequential Taillights, Summit O/R H Pipe Flowmaster 40s
Old January 4th, 2012, 10:56 AM   #3
Yes, my car always was a 5 speed. The Explorer was an auto (of course). Crossmember is out and the engine is tilted back. I just can get the spline on the output shaft to slide all the way in. I was thinking maybe the two dowels/guides in the '03 block are slightly larger and maybe that is a reason, but I doubt it.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
Old January 4th, 2012, 10:58 AM   #4
Authorized Vendor
BMR Tech's Avatar
BMR Tech will become famous soon enough
Polish the dowels with a dremel.
Polish the inside of the dowel opening on the bell.
Ensure there is nothing between the block/bell (wiring)
Slide the trans forward....if it doesnt want to go in...turn the crankshaft a little until it pops in.
Kelly Aiken "The Ford Guy"
BMR Suspension Inc
kelly@bmrsuspension.com
813.986.9302
CLICK IF YOU LIKE BMR SUSPENSION
Old January 4th, 2012, 12:39 PM   #5
1998 mustang gt
c-for is on a distinguished road
it could be that in 2003 the 4.6 with a 5 speed was not a t45 but was a t3650 so the input shaft size could be differant
Old January 4th, 2012, 01:28 PM   #6
You mean the length of the output shaft? The clutch is from a '98 and is 10 spline. The plastic clutch tool slides in w/no problem. I would think that if a t45 does not work with a new engine, that would have come up when I did a search, but you never know.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
Old January 4th, 2012, 06:52 PM   #7
zdkel's Avatar
zdkel is on a distinguished road
DId you install a new pilot bushing? The trans input shaft has to fit into that (thinking out loud).
96 GT - PI Intake & cams, O/R h-pipe, Flowmasters - 40s, Short Throw Shifter, 3.73 FRPP gears.
Old January 4th, 2012, 10:45 PM   #8
Yes, a new roller bearing type. Now, I need to replace one of the dowel pins, but it is seized in the block. Heat and PB blast has not helped the situation.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
Old January 5th, 2012, 09:35 AM   #9
Authorized Vendor
BMR Tech's Avatar
Knock it out form the front side..
BMR Suspension Inc
813.986.9302
Old January 5th, 2012, 10:54 AM   #10
Yes, I'm going to try that tonight if I can get something in there. Kind of difficult with the exhaust manifold on and w/ the engine in the car. I'll also try putting a tight fitting socket on it and wiggling it out.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
Old January 5th, 2012, 01:19 PM   #11
sj408 will become famous soon enough
Try to take her to dinner i hear the trannys like to be wined and dined
sorry i had to
Old January 5th, 2012, 01:27 PM   #12
double
Old January 5th, 2012, 03:35 PM   #13
sorry i had to
LOL, no harm done. As much as a pain the tranny is, it will be worth it.
'98 Mustang GT
'92 Mustang LX 5.0L
'11 Ford Focus SE
Threads Similar to: Problems Installing T45
Having Some Problems Installing CAI b1gdaddy98 V6 Mustangs 8 February 16th, 2010 05:06 PM
Problems since installing TB and Plenum....HELP! BakerFX4 99-04 78 January 5th, 2009 07:03 PM
problems installing off road pipe.help please nuffboost 99-04 2 March 19th, 2008 03:36 PM
05 GT installing BMR rear end poly bushing, having problems miloman 2005 - 2010 4 March 9th, 2008 03:00 AM
Installing Foglights Right Now, Ran Into Problems Top Gear V6 Mustangs 42 November 12th, 2007 03:58 PM
