Long Tube Install Help!
Old January 6th, 2012, 03:25 PM   #1
Pony Boy
blakenel1122's Avatar
9.84@148
blakenel1122 is an unknown quantity at this point
Exclamation
I got a set of Long tubes and were about to drop the new motor in. I was wondering if we should put the headers on the engine before dropping it in. Or should we mount the motor then put the headers on?
All help and advice is great!!
Thanks
-Flowmaster Force II Catback
-BBK CAI
Old January 6th, 2012, 03:49 PM   #2
1996 mustang GT
projectGT is on a distinguished road
I think its going to be difficult with your transmission on the way but its also hard with the engine in unless you drop the k
Old January 6th, 2012, 03:52 PM   #3
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Snug the headers on and measure the spread and see it if fits between the strut towers. Might wanna put the motor in with the headers and then install the tranny? Although trannys can be a bitch with headers.
GOOD LUCK! What headers are you installing?
Old January 6th, 2012, 04:32 PM   #4
Pony Boy
9.84@148
you mean with the tranny attached? and we dont have the tools or anything to drop the k
-BBK CAI
Old January 6th, 2012, 04:35 PM   #5
Pony Boy
9.84@148
Thats a good idea, thats what i think i will do but ill do it with out the gaskets cause i dont wanna ruin them. and Ill see if that would work, and you are right, lining up the tranny would be a pita.
and thanks!!! Ill need it. but i have flowtech's
-BBK CAI
Old January 6th, 2012, 05:33 PM   #6
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
You will not be able to install the tranny with the longtubes attatched to the motor. You will have to turn aournd and pull the headers to put the tranny in. Your best bet would be to stick it all in if it will fit.
Easiest way of course is to drop K-member.
Old January 6th, 2012, 09:15 PM   #7
Pony Boy
9.84@148
Yeah i didnt think it would work but you dont know till you ask! and you think i should put the motor and tranny in and then do the headers?
-BBK CAI
Old January 8th, 2012, 01:03 PM   #8
1996 mustang GT
Did you get it to work?
Old January 8th, 2012, 01:15 PM   #9
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
He is saying attach the tranny to the motor and then put the headers on then drop it all in together.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 8th, 2012, 02:10 PM   #10
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
^^^ best way to do it
MM FOBRA CLUB MEMBER #1
Old January 8th, 2012, 04:18 PM   #11
BAzombie's Avatar
1996 GT Convertible
13.88@100.71
BAzombie will become famous soon enough
Did not work for me.
When I did my heads and intake I pulled my motor & trans out of the car together.
My pass side LT was fine but I had to pull the driver side to get the motor out. I couldn't get the steering shaft to come out from between the middle pipes of the header.
Bolt your motor & trans together, install pass header then set everything into the engine bay.
Leave your motor attached to your hoist and keep it raised a few inches. This will give you enough clearance to set the driver side header in and still bolt it up to the heads. Then you can finish setting the motor down onto the mounts.
If you can, and I highly recommend it, get a set of Stage 8 locking bolts. They are well worth the money. NO LOOSE HEADER BOLTS EVER.
Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's
Old January 8th, 2012, 04:54 PM   #12
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I wish I had done this, I used a new stud set and am constantly having problems with the nuts backing off. When I replace my clutch and flywheel I am going to install the stage 8 setup instead.
MODS IN GARAGE
NCMM ORIGINAL
Old January 8th, 2012, 06:15 PM   #13
Pony Boy
9.84@148
Your a life saver man! My mechanic was saying how much of a pain in the butt longtubes are because of the bolts backing out and how they blow out header gaskets constantly. We just talked about this all today and I told him to skip the longtubes and just put the stock manifolds back on. but if he doesnt have the motor in with the stock manifolds on, Ill buy those bolts and have him put them in. and how well have they worked for you? have you ever had a problem with them backing out since you put them in?
THANKS SO MUCH!
-BBK CAI
Old January 9th, 2012, 12:40 AM   #14
BAzombie's Avatar
1996 GT Convertible
13.88@100.71
My LT's have been on for 3 seasons now.
I pulled them off after the 1st summer when I did my heads. Reinstalled after head swap with same bolts and locks. It's been 2 summers since my head swap and I've never had to mess with header bolt.
Old January 9th, 2012, 03:48 AM   #15
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
If you remove the steering shafter you can put it all in all together, I know I put a mark8 engine in with pacesetter longtubes installed with the trans on as well
Rock stock
Old January 9th, 2012, 08:39 AM   #16
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
You CAN put it all in together, and that's motor, transmission, and headers. I did it with a f*cking 03 Cobra motor, T56, and Hooker LT's, in the dark, alone.
Make sure you pull the steering shaft before anything goes in. One pinch bolt by the rack, one under the steering column. Take it out.
Stage 8 locking bolts are definitely a good idea. I know there's no way in hell I want to try and go back and tighten those bolts.
Last, a load leveler will help greatly. The toughest part is getting where the LT's bend past the motor mounts. It will probably take some trial and error. Or if you're an idiot like me, alone, in a rush, and in the dark, you'll probably end up scraping your headers on the mounts.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 9th, 2012, 05:49 PM   #17
Pony Boy
9.84@148
Wow, Im pretty mad. I wish this was like 2 days earlier. I told my mechanic to skip the long tubes and just throw the stock ones back on. I wasted like 400$ on these pipes and now I might just sell them because I don't have the tools to install these things my self. I thought my mechanic was going to be able to do it but I guess not. Thanks for all of the info though guys!
-BBK CAI
Threads Similar to: Long Tube Install Help!
Long tube install Newby 99-04 13 November 21st, 2010 09:19 AM
Long Tube Install Drtbkercr5 96-98 1 February 16th, 2009 12:54 PM
long tube install... njstang 99-04 13 September 16th, 2008 09:48 PM
long tube install 6banger96 V6 Mustangs 7 November 24th, 2007 04:48 PM
Long Tube install..... caintcatchmyGT 96-98 7 August 14th, 2007 11:01 PM
