IDLES ALL JACKED
Hey guys, i hope im in the right spot. I have a 98 cobra. It has idle problems. Some times when I initially start it, it will idle down to 400rpms, and almost stall out. then spike back up to about 1500. sometimes while driving it, ill stop at a light and the idle will stick at 1500 and after a few seconds calm down. It will also on first start and after running..will idle to 400 and fluctuate between 400 and 500 and bog down likes its missing a cylinder. I replaced plugs, checks msd ignition for back wire but seems fine. Ive cleaned MAF. I seem to hear some kind of what I think vac leak on right side of engine near plugs.....cant seem to loccate it pin point, I sprayed MAF cleaner on it and rpm's spiked up a small bit....would that be an indication of a vac leak?
VAC LEAK ? Maybe injectors? Or BAD fwd O2? Its got 3.73s, XPIPE,JLT CAI, MSD ignition, I cant grasp the problem??? THANKSSSSS@!!
ALSO THROTTLE RESPONSE, SOMETIMES WHEN I FIRST START IT, AND TAKE OFF IT WILL LAG WHEN I GIVE IT GAS.....LIKE ITS NOT GETTING WHAT IT NEEDS??? THROUGH THE GEARS....EVEN SOMETIMES WHILE AROUND 75MPH IT WILL LAG DOWN AND SEEM TO GET STUCK AND NOT WANNA CONTINUE TO ACCELERATE!!!!!!!!!
ahhhhhhhhhhhhhhhhhhhhhhhhh@!@#%%^(&^* |
Lake View Customs
1998 GT convertible 5 spe
I would check the intake. You might have a intake leak and it is sucking air. With it running spray around the intake and see if it changes the idle. If it does you have a intake leak. Its just like having a vac. leak. Let us know what you come up with.
Rollin' 18/ pushin' 2
He already said he had a leak at the intake.
1996 Mustang gt
throttle positioning sensor or TPS. i was trying to fix the wires that connect to this and notice that if these wires touch it would spike the idle at 2000rpm and wont drop down.
OK ILL check that out.... I have read a lot about maybe the o2's could be bad or maybe even the injectors...someone said if the altanator was bad then it sparks could be low....so many things@!!!! AHHHHHHHH
THANKS GUYS & GALS |
That would be the problem.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
how could I fix it or even isolate it tho
Wherever you were spraying the MAF cleaner when the rpm's increased...there is your leak.
Threads Similar to: IDLES ALL JACKED
| Headlights jacked up | Tank86 | 5.0 Mustangs | 1 | December 14th, 2011 04:38 PM |
| car all jacked up. what gives? | Tank86 | 5.0 Mustangs | 4 | July 26th, 2011 03:43 PM |
| speedo jacked up | HMUSN | V6 Mustangs | 7 | October 28th, 2008 09:31 PM |
| I think my fox is jacked up | blakehunter316 | 5.0 Mustangs | 23 | September 25th, 2008 12:15 AM |
