97 SVT oil pan replacement
Any of you know what all you need to pull/ do to replace an oil pan on a 1997 Cobra? My friend has one and is looking to have the pan replaced at the shop i work at. Labor guide calls for 8 hours to do it. Does it require pulling the engine or dropping the front suspension?
![]() 2000 CSVT 03 Escape 3L block, 02 Mercury Cougar 2.5 heads, SVT cams untuned. Stock manifolds, short ram intake, MSDS Y pipe, stock exhaust. 195whp/182wtq 1985 Honda 450 Nighthawk 70+MPG average 8200 miles and counting
Moderator
it would be easier to just drop the K
![]() ![]() BUILD 2 IN PROGRESS |
I'm reading through a removal procedure from one of the website we use at my work. It says to remove the transmission
Lake View Customs
1998 GT convertible 5 spe
If he takes it to the dealer they wont pull the engine. They will drop the sub frame to get to it. Its not that bad if you have a twin post lift to do on and right tools. The engine will have to be supported from the top. It can be done in your shop at home if you have a good skill level and tools. I have been in the business for 20 years I would have no problem doing it but with out the tools and skills dont attempt it. Try a local shop other than the dealer to compare price. Hope this helps you out.
Moderator
i think that they are talking about dropping it, unbolting the bolts, then sliding it out. I still think that supporting the engine then dropping the K would be sooo much easier.
#6 | |
I'm just trying to get an idea of what i'm in for. Last thing i want to do is mess anything up on this car. I have a few years of experience under my belt, but this isnt your every day cobra. ![]()
Moderator
nice looking snake... its not bad at all
5L forged stroker, not sure if he made it back to the dyno, but he said they were going to be bumping up the boost a little bit and he should be around the 450HP mark.
Lake View Customs
If you have a lift you might be able to pull the trans and slide it out. I have never done it that way. I am not sure if you have the room to drop the pan down enough to get off the oil sump. Keep us posted on your progress.
i'll be sure to take pics. Like i said above, i work for "the small shop" so i have lifts and just about any tool you can think of. I hope it all goes smooth.
MM's DRUNKEN SAILOR
the tranny HAS GOT TO come out to get the pan off. found this out when i was putting in the return line on my turbo. and the fron suspension needs to be dropped. if you have a lift its 4 or 8 bolts and then lift the car and the frons suspension is out. then you will need 600,329,786 3" extensions all put together to get to the starter through the front bumper lol. the rest of the trans bolts are pretty easy. i did mine in a driveway in about 3 hours out and back in.
![]() MILITARY CREW GSM3 i love throbbing meat
Moderator
hmmm... curious, what is the reason why you have to remove the tranny just to remove the oil pan?
MM's DRUNKEN SAILOR
because you need to be able to pull back on the oil pan to get around the pickup tube. and it makes it way easier to get to the bolts that are on the backside of the engine.
Moderator
Good to know... never had that problem though. You would be able to get around the pick up tube if you were to drop the k, unbolt it, and just drop the pan instead of pulling it back. Gonna have to look at my old pan and block
MM's DRUNKEN SAILOR
yes and no. the room between the oil pan and tranny is just barely enough to put a sicket into on a 1/4" drive. so taking the ranny back just a little bit really sped things up.and i did my on the ground too. so i only dropped my k-member and such about 8-10 inches.
Moderator
I see what your saying... I guess I never had a problem cause I always used an open/closed wrench to take those bolts out ( 2 IIRC ) then I just used my crows foot with the extended ratchet attachment to torque her down to specs.
Great info guys. thanks!
Threads Similar to: 97 SVT oil pan replacement
| CD Replacement Help | CodyNelson | 99-04 | 6 | October 7th, 2011 02:06 PM |
| MAF replacement...help please | newsatng | 99-04 | 7 | April 18th, 2011 06:53 PM |
| CAI or replacement K&N | a_kraker99 | V6 Mustangs | 9 | November 27th, 2008 01:59 AM |
| MAS replacement? | 1995svtcobra | 94-95 | 0 | August 11th, 2007 08:55 AM |
| Key Replacement...?? | 98mustangfla | V6 Mustangs | 7 | June 11th, 2007 03:50 PM |
