Cruise Control not working.... Broken resume button?button
Old January 14th, 2012, 11:58 AM   #1
justinscher is on a distinguished road
Hey, my cruise control quit working a while back and the horn works, no air bag light, and the turn signals work. However, there is NO feel in the resume button, seems all the way down and it rattles. Just curious if any one has seen this before. Would like some feed back before shelling out money for the new switches. Thanks.
Old January 14th, 2012, 12:12 PM   #2
MM's DRUNKEN SAILOR
deedub97GT's Avatar
single turbo in the works
as fast as i can push it!
deedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to beholddeedub97GT is a splendid one to behold
Send a message via Yahoo to deedub97GT
check your cruise control cable. its directly under your throttle cable. if its off or loose then the cruise wont work. we have mechanical cruise control on these cars not the electronic stuff like newer ones. lol welcome to the forums man!
MILITARY CREW GSM3
i love throbbing meat
Old January 14th, 2012, 01:16 PM   #3
Thanks for the input. Cable is attached and not exactly what I would call loose, if you pull on it moves about an inch.
Old January 14th, 2012, 01:26 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
It should move like that. I don't think that is your issue.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 15th, 2012, 11:51 AM   #5
Yeah, thats what I figured, and looking at the billet buttons on AM it seems that the resume button could break and then have no feel and not work and rattle, so I guess I'll shell out the $35 bucks for the replacement units on ebay and see if that takes care of it. I'll let you know if that works
Old January 15th, 2012, 05:45 PM   #6
1998 Mustang GT
MustGT98allday will become famous soon enough
im interested cuz my cruise doesnt work either
pi swapped and dropped sn95
Old January 15th, 2012, 07:08 PM   #7
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
could be that . Also check the clutch switch. There is a switch that disables it when pressed. if that is bad it will prevent it from working .
do note that it is not the same as the clutch start switch. This CC switch is located at the very top of the clutch.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Threads Similar to: Cruise Control not working.... Broken resume button?button
Installed Push-Button-Start. Heater/AC buttons not working N1ccay Electrical & Wiring 1 December 9th, 2011 11:26 AM
is there a fuse for traction control button? sharpshooter33 99-04 3 November 23rd, 2011 12:05 PM
Trac control button problems Gerbig 99-04 6 October 17th, 2011 09:37 PM
Broken O/D Off Button wire Cobra311 V6 Mustangs 3 October 25th, 2009 11:24 PM
resume button? zack065 2005 - 2010 10 June 4th, 2008 12:07 PM
