LinkBack (2) | Thread Tools |
#1
SVO INTAKE SUPERCHARGER GUYS NEED HELP!!!!
Ok so i put another engine in my car after my last one had blow by and burning oil. and oil coming out of my air filter. Ive put about a 1k miles on this one and i walked out to my car last night to notice ive got a nice oil spot right under my passenger side fender. i look at my air filter and the bottom part is just soaked in engine oil. pulled the intake off the throttle body and there is oil inside there.
My set up for those that dont know is a 96 GT NPI heads SVO Intake manifold with the SVO Eaton Blower Please anyone that knows these bower set up give me a lead. im completely lost as to why its doing this again. last time the passenger side had very low compression like 45-50PSI i have not tested the new engine yet but I will soon. |
Hooo Ha Ha
Well first off who tuned the car?
What injectors does it have in it? How much boost are you running?
![]() 410rwhp 520rwtq @ 12.9 psi |
2000 gt
ya you just went through this. hope it's not the same thing again man, but sure sounds bad.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
It has a bullsh!t dord racing tune i was just about to have it tuned right and this happened. Its got 30lb injectors and it pushes 5-6 lbs of boost
2000 gt
ya get a custom dyno tune for sure. those canned or mail order type tunes aren't optimal for every situation. good luck man i hate to see this. i would love to have one of those little blowers.
i think it was sharkbait that had one of those if i'm not mistaken.
Rollin' 18/ pushin' 2
Wow, I have no clue why you keep having this problem. Did someone rebuild the charger? Sounds almost like it is sucking air instead of blowing it.
Hooo Ha Ha
Mine had alot of oil in it after i blew the motor.
Did you by chance replace your PCV valve or valves recently? Maybe they're stuck open
1998 Mustang GT
the only way i know of oil getting to the filter is the pcv system. make sure your pcv system is good.
pi swapped and dropped sn95 |
^^^ what he said Something just isnt happening right man look over everything.
MM FOBRA CLUB MEMBER #1 |
Hooo Ha Ha
You should look into running a catch can.
Post a pic of how your lines are routed and i can compare them to mine if you want.
if its running rich oil pushes past the rings. get it to tuner, change the oil. on the dyno they should be able to reseal the rings on a couple runs.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/245935-svo-intake-supercharger-guys-need-help.html
| Thread SVO Supercharger | TCCoA Forums | BoardReader | This thread | Refback | February 8th, 2012 12:36 PM | |
| svo supercharger - forum communication | BoardReader | This thread | Refback | January 24th, 2012 06:31 AM | |
Threads Similar to: SVO INTAKE SUPERCHARGER GUYS NEED HELP!!!!
| Oil question for supercharger guys | rider4life350 | 99-04 | 30 | March 21st, 2011 01:01 PM |
| supercharger guys.... | BakerFX4 | 99-04 | 75 | January 23rd, 2010 01:41 AM |
| supercharger guys | ia07gt | 2005 - 2010 | 27 | December 10th, 2009 06:59 PM |
| Another question for the supercharger guys.. | BlackSunshine | 99-04 | 3 | September 14th, 2009 12:40 PM |
| quick help.. tell me what you guys think of this supercharger | 03StangGT | 99-04 | 14 | February 28th, 2008 10:03 PM |
