14.99@90
Ticking Noise After PI Swap
After finishing my PI swap the motor is making a really bad ticking noise on startup that continues til the car warms up really good and has been running for a while. Its a steady constant tick that will go away after some amount of time unless the motor is in a certain power band under load then it never really goes away. When I did the swap I put in new lash adjusters in the head and was thinking that maybe this could be the culprit. The only other thing that I could think of is that I also got a new timing set and put new tensioners, guides, chains and gears on it when I did it. The new tensioners were not the same as my '96 but the instructions said they were just an improved design and would work just the same. They do not have the ratcheting system like the original 96s do.
That being said I've decided to go ahead and change the lash adjusters. I do have the tool that you are supposed to use to get the adjusters out. I was able to get the passenger side adjusters out without removing the cam no problem. But have run into a problem on the driver side where the master cylinder and brake booster is in the way. Is there an easier way to remove the last adjusters on the drivers side without removing the cam? TLDR: Can you get the lash adjusters out on the drivers side without removing the cam. And what other kind of noise could it be if it turns out to not be the lash adjusters? Thanks for the help in advance. btw 1996 Mustang GT Romeo PI Swap. Sent from my Autoguide iPad app |
1997 Pacific Green Cobra
14.80 No traction
Sounds like stuck lash adjuster or one that wont pump up. if its not lash adjusters then it would be...a rod and its not oging to be that so its lash adjusters.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
1998 Mustang GT
![]() iTrader: 2 reviews
sounds like lash adjuster to me not sure i can help you with getting the driver sides out. maybe rip off the master cylinder real quick and push it out the way?
pi swapped and dropped sn95 |
98 Mustang GT
![]() iTrader: 1 reviews
Sometimes adding some MMO and running it for awhile can unstick lash adjusters and get chain tensioners to pumpup which can make a ticking sound, just went through this with mine. Doesn't take much 4-6ozs
98gt, pi intake, jlt cai, flowmasters, black bullits, hurst comp-plus, custom hpipe, eibach sportlines, 373gears |
Were they from Ford or an aftermarket manufacturer/supplier? A number of people have had issues with off-brand lash adjusters in these engines.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
Threads Similar to: Ticking Noise After PI Swap
| ticking noise after PI swap | justin025 | 99-04 | 47 | April 29th, 2010 09:39 AM |
| ticking noise | easye88 | 99-04 | 13 | April 21st, 2010 11:55 AM |
| a ticking noise | 87gtmustang | 5.0 Mustangs | 2 | February 4th, 2009 03:27 PM |
| bad ticking noise | 01 RED GT | 99-04 | 11 | January 10th, 2009 09:18 AM |
| Ticking Noise? | 99Rumblebee | V6 Mustangs | 3 | September 27th, 2008 12:08 AM |
