Help on modification
Old January 16th, 2012, 12:52 AM   #1
Mustang GT 1997 N/A
13.59@ 97.52
Wilo1x is on a distinguished road
Hey guys its been a while since i been on the page well i just came back from the dyno my car did 295.hp 335 tq. I was expecting a little more, what more can i do to the car?
Here is what its currently on the car:
Full PI Swap
BBK intake
Stock gears
Stock Coils
10mm ford racing cables
Flowmaster
Magnaflow X pipe
Stock tail pipes
Springs( 1.5F 2.0R)
SCT tuned
Old January 16th, 2012, 01:37 AM   #2
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
No cams or intake?
Id say thats pretty good. 295rwhp is pretty freaking nice for a stock head/cammed car.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 16th, 2012, 12:49 PM   #3
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Those are very good #'s.
Add some longtubes.
MM FOBRA CLUB CO-FOUNDER
Old January 16th, 2012, 02:25 PM   #4
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
Dont get LT's your car will gain very little if any HP from them. And for that money, you could get yourself some nice comp 270's or equivalent cams and gain lots of power. That, a dyno tune and some 4.10's and you'll have a very fun car.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old January 16th, 2012, 03:08 PM   #5
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Those are great numbers! Cams can do wonders.
Old January 16th, 2012, 03:49 PM   #6
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Not doubting you but those numbers cant be right.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old January 16th, 2012, 07:02 PM   #7
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
^ Thats why I questioned no cams or anything...IDK...
96 GT-Cammed E85
www.KPERacing.com
Old January 16th, 2012, 11:17 PM   #8
wveil3v's Avatar
98 Mustang GT
wveil3v is on a distinguished road
Full PI Swap
BBK intake
Stock gears
Stock Coils
Flowmaster
Magnaflow X pipe
Stock tail pipes
Springs( 1.5F 2.0R)
SCT tuned
those are good numbers, also how do you like the xpipe sound with the flowmasters? Did you like the sound right away, or did it take getting use to it and hows the drone?
98gt, pi intake, jlt cai, flowmasters, black bullits, hurst comp-plus, custom hpipe, eibach sportlines, 373gears
Old January 18th, 2012, 11:11 PM   #9
Mustang GT 1997 N/A
13.59@ 97.52
Well i got used to the drone but im looking to change the flowmaster with some loudmouth.Yes the numbers i gave you are correct and im looking to upgrade the cams now glittle 75 you mentioned 270 comp cams im this close to buying one but a friend of mine keeps saying that those cam dont work. Whats your take on those cams? Also i know that there at least three stage cams correct me if im wrong, i know the obvious reason its to go with the first stage but which works better with stock heads?
On a side note the other day a guy asked if my car had flat top pistons which i really dont know cause i bought the car from a guy in PR. Is there anyway to really know if you got flat tops or does car even have flat tops with those heads without taking apart the heads?( im noob at mustang lol )
Old January 19th, 2012, 12:19 AM   #10
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
If its a stock NPI bottom car...its around a 9cc dish if I remember correctly.
If you are looking at a stage 2 cam (ie 230s duration@.050) you NEED to degree them and check PTV clearance. If not...im pretty sure without a doubt you will have PTV contact.
96 GT-Cammed E85
www.KPERacing.com
Old January 19th, 2012, 12:39 AM   #11
Mustang GT 1997 N/A
13.59@ 97.52
I got PI heads my friend the one that said that those cam didnt work for him had NPI. Where can i find some Cams for a decent prices cause im on a budget lol have to paint the car again and change the rack and pinion of the car.
Threads Similar to: Help on modification
seat modification mustang95 5.0 General Tech 10 January 24th, 2011 06:01 AM
Modification advice 99GT4.6HO 99-04 17 December 24th, 2010 07:27 PM
My first modification !! Easy Rider 5.0 Mustangs 2 March 25th, 2010 09:53 AM
lil modification pulease G.T. Rags Chopshop 19 February 22nd, 2009 11:49 PM
Exhaust modification KIKa55GT 96-98 4 January 16th, 2008 01:37 PM
