Questions about lowering
Old January 16th, 2012, 05:55 PM   #1
V8ornothing's Avatar
97 Mustang Cobra
V8ornothing has a spectacular aura aboutV8ornothing has a spectacular aura about
So I'm looking at buying a set of lowering springs, do I need caster camber plates for springs like the ford "b" springs? Anything else I need to know? These would be getting paired with koni double adjustable shocks and struts if that means anything.
Ryan's Baby Mama
MM Jailbait Club member # 1
Black Stang Crew Member
#Halfrican
mgw short throw shifter, upr catted x pipe, Borla Stinger catback, mac cai, subframe connectors, koni adjustable shocks and struts
Old January 16th, 2012, 06:45 PM   #2
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
Yes i would also get some steeda x2's also are you will be eating tires for breakfast.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old January 16th, 2012, 07:32 PM   #3
1998 Mustang GT
MustGT98allday will become famous soon enough
i would get caster camber plates to help with the alignment. i have eibach sportlines with caster camber plates and still cant come even close to within spec on my caster or camber (and thats with the plates in the most postive position it can be.)
pi swapped and dropped sn95
Old January 17th, 2012, 04:54 PM   #4
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
i had those springs at one time...i didnt run anything other than those and shocks/struts (KYB GR2's) it DID wear the tires on the insides but i never took it for an alignment. i would go ahead and get the CC plates just to make sure you can get it back in spec (or at least close) the steeda X2 balljoints are another thing i'm looking at doing soon along with a bump-steer kit, especially now that i've got H&R SS's with no iso's.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old January 17th, 2012, 05:10 PM   #5
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
IMO B springs don't really lower it enough to need c/c plates. It should be able to be aligned it within specs without them.
MM FOBRA CLUB CO-FOUNDER
Old January 17th, 2012, 07:53 PM   #6
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Agreed. 2" drop I would get cc plates but not for anything less.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 17th, 2012, 09:06 PM   #7
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
What about steeda springs in stock struts and sho ks
MM FOBRA CLUB MEMBER #1
Old January 17th, 2012, 09:47 PM   #8
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
I just ordered the C class springs last night. I went with that because its a linear spring instead of progressive. From what ive been told you will not need CC plates for it.
Old January 17th, 2012, 10:15 PM   #9
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
CC plates are not "needed" but are a good idea, even if you DON'T lower the car
They allow much more adjustablilty for all things alignment, but most importantly, caster. Wider wheels like more caster and if you want to remove the camber one gets from lowering the car, they will allow one to get into OEM specs, where you will have trouble doing so on a moddest drop without them.
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 18th, 2012, 12:06 AM   #10
97 Mustang Cobra
Ok so I passed up the b springs because I feel as though for the price I may as well go new or keep looking. What springs do you guys recommend without going so low I'm unable to get in driveways.
Ryan's Baby Mama
#Halfrican
Old January 18th, 2012, 10:50 AM   #11
termi_GT's Avatar
12.41@114
I am a big fan of Votglands. Their ride qaulity is the same as stock and the stance is perfection IMO.
Old January 18th, 2012, 10:58 AM   #12
Authorized Vendor
BMR Tech's Avatar
BMR Tech will become famous soon enough
Jazzer
Great info, I agree 100% with this.
I would (and have) CC Plates on every 79-04 I have owned/own....regardless of ride height.
Kelly Aiken "The Ford Guy"
BMR Suspension Inc
kelly@bmrsuspension.com
813.986.9302
CLICK IF YOU LIKE BMR SUSPENSION
Old January 18th, 2012, 07:44 PM   #13
sn95mustanggt's Avatar
98 GT, 93 Ranger!
sn95mustanggt is an unknown quantity at this point
Running those springs and im within specifications, they wouldnt hurt though.
1998 Mustang GT-S/C Teksid in the works
1999 Mazda b3000- DD
05 Rancher - 4x4
07 zx6r
2009 Kfx450r
yz 125
98 banshee- for sale
Threads Similar to: Questions about lowering
Lowering questions KPOD V6 Mustangs 42 July 18th, 2011 12:10 AM
questions about lowering. SNmustang95 94-95 8 December 12th, 2010 11:17 PM
Lowering Questions Six Banger V6 Mustangs 19 October 18th, 2010 08:10 PM
lowering questions icon 2005 - 2010 V6 6 May 9th, 2009 08:00 PM
lowering questions texas_mustang 2005 - 2010 15 July 21st, 2007 12:26 AM
