1.5" rear wheel spacers
LinkBack (3) Thread Tools
Old January 16th, 2012, 09:58 PM   3 links from elsewhere to this Post. Click to view. #1
1998 Mustang GT
ViBrationnc is on a distinguished road
Hey.. I've seen these things around... http://www.americanmuscle.com/1in-bi...l-spacers.html and also noticed that my 98 gt rear wheels seemed to be a bit tucked in? Anyone else feel the same? Are these spacers a good Idea.. looks? Any performance issues? Or should I go with a rim that has a greater offset? I currently have stock cobra rims 274/40/17.
Thanks.. if anyone has any pics of a before and after.. that would be great too..
Thanks
Old January 16th, 2012, 10:24 PM   #2
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
These are with s197 rims but you still get the point. Best visual thing ive done to my car, makes it more appealing and tough looking. Yes these are the 1.5'' spacers.
Before:
After:
Old January 17th, 2012, 08:32 AM   #3
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
VIB.... 1.5" spacers are a bad idea
Not only because they create an additional strain on the axles/OEM studs, but hate the idea of having a "hidden" set of lug-nuts. Moreover...do you know a 1.5" spacer will work? Have you measured to confirm? I am guessing you have '96~'98 Cobra wheels that are 8" wide with a 275 tire on them? This is too wide a tire for a proper fit on an 8" wheel, so one more reason to get a wider set of wheels.
If you were to get a set of 9" wheels that were designed for your '98, you could use the tires you have, but with the correct off-set. This would move the wheel outward about 1/2" and fill the wheel-wells better with a properly fitted tire
Jazzer
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 17th, 2012, 03:22 PM   #4
1998 Mustang GT
Jazzer.. I am not sure of the exact year or size of the rims.. I will get back to you on that. T
Old January 17th, 2012, 07:08 PM   #5
1998 Mustang GT
MustGT98allday will become famous soon enough
or upgrade the wheel studs!
pi swapped and dropped sn95
Old January 17th, 2012, 07:51 PM   #6
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Over rated. It sucks visually too. I have upgraded studs on the rear and now have to run an open lug nut. It looks like ass IMO.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 17th, 2012, 09:32 PM   #7
Abyssinian of AX
'02 Saleen
19.34@42.259
Cut them down so that they are ONLY as long as needed
I run a set of 1/2" spacers out back on my car and had studs custom milled to my specs for a full 1" of thread contact and closed-end nuts. You can do it yourself, with some handy tricks, but was getting new axles installed at the same time, so had my shoppe do it for me at the time
Jazzer
Old January 18th, 2012, 07:50 PM   #8
sn95mustanggt's Avatar
98 GT, 93 Ranger!
sn95mustanggt is an unknown quantity at this point
jazzer is right, causes more wear. I have been running a 1.25 inch spacer out back for over a year now. Appearence looks great. Im not to worried about the wear because i only put maybe 2k miles on a year.
1998 Mustang GT-S/C Teksid in the works
1999 Mazda b3000- DD
05 Rancher - 4x4
07 zx6r
2009 Kfx450r
yz 125
98 banshee- for sale
Old January 18th, 2012, 08:07 PM   #9
bens98gt's Avatar
1998 Mustang GT
bens98gt is on a distinguished road
The 1.25 is the best, I switched to my 10.5s last summer but when I run 9s all the way around the 1.25s were perfect. The tires were flush with the fender. I still run them on track when I put my 17x9 race tires on.
98 Mustang GT Mods:Flowmaster 40's Pypes O\R X-pipe Ram Clutch BBk CAI Pro 5.0 Shifter. mm c\c plates, 3.73s, cobra brakes with stainless lines, hawk blue pads and bfg r1 race tires. (for track) Ford racing race springs. Black DD FR500s
LinkBack to this Thread: http://www.moddedmustangs.com/forums/96-98/246245-1-5-rear-wheel-spacers.html
18x9s, 265x35 tires, 1.5 inch wheel spacers - Page 2 - MustangForums.com This thread Refback March 11th, 2012 07:26 PM
18x9s, 265x35 tires, 1.5 inch wheel spacers - MustangForums.com This thread Refback January 18th, 2012 03:15 AM
18x9s, 265x35 tires, 1.5 inch wheel spacers - MustangForums.com This thread Refback January 17th, 2012 10:44 PM
Threads Similar to: 1.5" rear wheel spacers
Will I run into any issues running 1/2" wheel spacers on the rear hubs? asiansensation78 99-04 11 December 25th, 2010 04:32 PM
