1998 Mustang GT
13.8 @ 99mph
![]() iTrader: 1 reviews
EFI Fittings and Connectors
Whats up fellers, Was wondering if this fitting would work with the connectors that are on the feed and return lines that hook up to the feed or return nipple at the fuel hat?
This is actually for GM or Chrysler but it looks the same as the ends on our fuel hat lines.http://t2.gstatic.com/images?q=tbn:A...5Sp-Al5Golkk1g
Car's out back ![]() "Excuse me,
Your balls are showing." ![]() |
1998 Mustang GT
13.8 @ 99mph
Anybody...
1989 LX Coupe
7.1@99mph
That would be the correct TYPE of fitting. But not sure on the size.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20 01 Bullitt-32v swapped 96 GT-Cammed E85 www.KPERacing.com |
1998 Mustang GT
13.8 @ 99mph
So this so called GM Chrysler EFI fitting is the same as the one we have on the fuel hat (Actually the end part). I dont think they come any smaller than -6 AN
Proud American
Thats not what I would use...
Here is what I would use... http://www.summitracing.com/parts/EAR-165056ERL/ cut the factory line connection off and slide this on... I don't know the size of the factory lines though... Mine are long long gone.
1998 Mustang GT
13.8 @ 99mph
Am i gonna need to flare the end of the tube to us that
Proud American
no you put the red piece on the tube, and then slide the ferruel on the tube and then tigthen the blue piece to the red piece and it makes a strong connection for you. When I built the fuel system for my diesel pickup this is what I used. Factory lines to the engine bay and then from there cut and put these on for return and feed.
1998 Mustang GT
13.8 @ 99mph
Another question, those female AN EFI connectors that are used on the male connector I have on my first post, will they connect on our fuel hat.
SHHHHH...Do you smell that?
#9 | |
1998 Mustang GT
13.8 @ 99mph
Proud American
I have 75 psi on mine every day... never had a failure... and those ones might be rated that high, but aeroquip or somebody else might make a heigher rated one... If I remerber correctly mine are XRPs
1998 Mustang GT
13.8 @ 99mph
I guess it would be ok on the return. I'm using the factory feed for the return. Ill prob go steel braided on the feed. Aeroquip most likely.
1998 Mustang GT
13.8 @ 99mph
What hose did you end up using after you got rid of the hard lines? Did start smelling of fuel.
Proud American
I have used braided steel line, push loc blue hose, and now am on nylon feed and return lines...
![]() ![]() Thats around 500 bucks in fittings and a regulator that you can't see... Braided steel line is fine too, the push lock isnt pretty, but will work well too.
1998 Mustang GT
13.8 @ 99mph
One more thing arent you gonna have that vapor stench in you garage when you use the regular braided line?
Thanks for the info
Threads Similar to: EFI Fittings and Connectors
| Grease Fittings?? | Rankus06 | 2005 - 2010 | 1 | November 5th, 2011 10:36 PM |
| 8.8 Rear Fittings | I SN95 I | V6 Mustangs | 7 | September 13th, 2010 06:25 PM |
| Grease Fittings | MustGT98allday | 96-98 | 5 | August 23rd, 2010 08:39 PM |
| Duckbill fittings? | Uber88GT | 5.0 Mustangs | 0 | March 21st, 2010 08:54 PM |
| Pi-Thon Compression fittings | nem | 2005 - 2010 | 0 | June 27th, 2007 06:32 PM |
