1996 mustang gt
n/a
breaking up at 3k
my 96 gt pi started running like crap yesterday. everything was fine and now
it seems to either lose spark or fuel and kinda sounds like a two steep at 3k rpm. I'm not sure what it could be because as soon as it gets past 3k it stops and will run fine again . i have changed the plugs and cleaned the maf and it is still doing the same thing. any advice would be grate . |
1998 Mustang GT Convert.
check your coils, fuel filter, and change your plug wires. check your gap also. thats some ideas for ya to check.
98 Mustang GT Convert. 95 Mustang GT 5.0L |
1996 mustang gt
n/a
thanks . changing the plug wires and the full filter is easy but how do you check a coil to make sure it is OK ? plug gap is OK checked that last night . i also replaced the maf last night and it seems to be running a little better . at least it did this morning wile taking the kids to school .
The Hammer
Millenium Falcon
check to see if your intake manifold is cracked....
my old 96 used to do that when it was cracked in the front and back of the intake.... |
1997 Mustang GT
Sounds like TPS to me. When a TPS sensor gets worn out it will normally malfunction at a certain rpm range that it sees alot. So it will work at all rpms until it gets to the bad range and then straighten out after that range has passed. Only way to be sure is to either use a meter with an oscilloscope on ur tps sensor or use a scan tool to graph it while driving. Very common problem.
![]() PI Cam Swap, MAC C/A intake, BBK 70mm TB, C&L Plenum, Ford 24lb injectors, March UD, 160 T Stat, MSD ignition, 3.73 gears, Stage 2 Clutch, Steeda Short Shifter, O/R X, Flow 40s, SCT Race Tune. |
1996 mustang gt
n/a
thanks for all the help everyone . i found the problem to be bad plug wires so i replaced them and the problem is gone .
Threads Similar to: breaking up at 3k
| braking problem | MIGHTYJO3YOUNG | 5.0 Mustangs | 9 | January 21st, 2011 02:06 PM |
| Car died under braking? | therat1989 | 99-04 | 2 | June 16th, 2010 05:47 PM |
| braking | 95stangvert | 94-95 | 23 | September 25th, 2008 01:31 AM |
| braking and weatherstripping.... | dgt_mustang | V6 Mustangs | 8 | September 5th, 2008 05:39 PM |
| Braking bad | whitemustang02 | The Clubhouse | 8 | March 9th, 2008 11:39 PM |
