engine noise
Old January 19th, 2012, 11:39 PM   #1
jrcurtis00 is on a distinguished road
Question
engine noise
I have a 97 Mustang Gt 4.6l. I had the engine replaced and ttransmission rebuilt soon after I purchased the car because of high milage, a few leaks here and there, and I wanted to upgrade to PI heads. After installation of the freshly built engine I have a noise that seems to be coming from the engine compartment. Similar to a valve rattling noise. Only when engine is cold. and in high rpm situations . Usually starts around 2800 rpm. But car has to be moving. You can pull up to a stop sign, knock it out of gear and rev it as high as you want and it never knocks or rattles.Anybody seen this before? Any ideas on how to eliminate possible culprits like a lifter noise or timing chain tensioner noise? Also, I may try to do a compression test tomorrow. What should the compression be with PI heads on a non Pi block? Thanks for any help.
Old January 19th, 2012, 11:49 PM   #2
Zip wants me
Durr4456's Avatar
2005 Mustang GT, 1967 GT
Durr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of lightDurr4456 is a glorious beacon of light
I'm no genius so just a guess that there isn't a lubrication because the engine is cold. Shouldn't be revving high up anyway with a cold motor. Someone else will come along with a more knowledgable answer though.
The day I finish paying for my mustang will be a great day. Although I'm more likely to die before it happens. Don't be stupid like me!
Zip loves my penis.
Old January 20th, 2012, 12:05 PM   #3
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
^This is true.
Did you have your driveshaft lined up properly onto your diff? Is it backwards?
The compression should be around 10.5:1
Old January 20th, 2012, 12:31 PM   #4
yamanx's Avatar
1998 Mustang GT
yamanx is on a distinguished road
Put some octane booster in your fuel and see if it goes away.
Mods: Full Griggs suspension, Koni coilovers, Cobra brakes with SS lines, sub frame connectors, 3.73s, 5-speed swap, TR6's
Old January 20th, 2012, 02:53 PM   #5
Traction...?
1996 GT's Avatar
I'd advise against octane booster. Cars tuned for 87, therefor should be staying on 87.
Old January 21st, 2012, 05:05 PM   #6
Driveshaft is on right. And the noise seems to be from the front of the car. I understand noises will travel thru the drivetrain. It would be much easier to diagnose if you duplicate the noise while sitting still with the hood up. Thanks for compression rario.
Old January 21st, 2012, 05:09 PM   #7
I havn't tried the octane boost yet but I di put the high grade fuel in with no improvement. It seems to be pronounced than a detonation problem. I'm not a engine builder- by far- but I lean toward thinking it's a bad lifter. Thanks for your input.
Old January 22nd, 2012, 08:05 PM   #8
yamanx's Avatar
1998 Mustang GT
You won't hurt anything running the Octane booster, just worth a shot.
And there are no lifters in the 4.6..so that is not your issue.
Old January 22nd, 2012, 09:48 PM   #9
I sometimes refer to the lash adjusters as lifters. sorry for the confusion.
Old January 23rd, 2012, 12:00 PM   #10
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Is the car tuned? The OP didn't mention that it had been.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old January 23rd, 2012, 06:42 PM   #11
yamanx's Avatar
1998 Mustang GT
Haha well I guess at least you prefaced it with admitting you're not an engine builder But Lash Adjusters and Lifters are two completely different things so you should probably only refer to LA when talking about your motor.
But with the PI swap it is very possible that your engine just needs a little octane boost to help with detonation, I have seen it happen before, comes with the higher compression ratio.
Threads Similar to: engine noise
engine noise 01COBRA 99-04 6 November 14th, 2010 08:08 PM
Odd Noise From Engine Bay 04stang123456789 V6 Mustangs 26 October 20th, 2009 03:13 PM
Camshaft Phaser Noise - Engine Noise - Help! xxxcobraxxx 2005 - 2010 6 May 27th, 2009 09:20 PM
engine noise orangemonster 2005 - 2010 34 March 5th, 2009 10:01 PM
Engine noise energiesource 99-04 4 May 17th, 2007 02:43 PM
