new to mustangs.
Old January 23rd, 2012, 01:37 PM   #1
1badtib is on a distinguished road
new to mustangs.
Okay so i have a 96 gt that i got that wasnt running. the fuel pump was bad and i replaced it with a walbro 255. it has a few things wrong with it that im not sure what it could be so if you could help me it'd be greatly appreciated!!
1. when i press the brakes, the pedal like goes to the floor before it actually stops the car.. like i have to press it quite far.
2. i have to push the clutch 100% all the way in before i shift or it will grind. is this normal??
3. when i drive it hard and let off, i hear a clunking in the front. I'm guessing the engine is hitting something?? possible motor mounts? i was looking at solids but cant find a trans mount.. i think i read somewhere if you do motor mounts u need to do trans mounts?
4. ebrake doesnt work at all cables are gone u think)
5. odometer doesn't work.
Old January 23rd, 2012, 01:46 PM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Flush (not just bleed) the brake system. Should be done annually and I doubt it was ever done at all.
Not normal, but these cars use a clutch cable which stretches over time, so it's not unexpected. I recommend replacing the whole setup with an aluminum clutch quadrant and firewall adjuster, but you can just replace the cable and reset the auto-adjusting plastic quadrant.
As a preventative, it'd probably be a good idea to replace the tranny fluid, GM Synchromesh is the best fluid for T45s.
Motor mounts would be my first guess, though I don't recommend solid mounts on a street car. I'd do the trans mount at the same time, but it's certainly not required. If you're not finding the trans mount, you're not looking very hard, at the very least you should be able to find one at either Late Model Resto or Rock Auto.
Possibly. Could also just be way out of adjustment, or your rear brake pads might be shot.
Just the odometer, or does the speedo not work also? If it's both it's the speedo cable or the gear at the end of the cable; if it's just the odometer, there's a separate odometer gear in the cluster that is replaceable, I *think* you can get the part from LMR, I know I've seen at least one thread about it so a search should be fruitful.
O o
/¯/______________________
\_\
Old January 27th, 2012, 01:58 AM   #3
just the odometer doesnt work. also is there a walk through for the clutch cable?
Old January 27th, 2012, 10:20 AM   #4
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Air in the brake system.
Are you slamming gears or taking a bit of time?
Trans mount it a DEALER only part, its only rubber, no urethane or solid.
Is it a 5 speed? They did have a recal on these cars for them. Check your cables for rust or corrosion or breakage.
Beveled gears behind the tach. They are plastic and wear out over time.
1994-98 Mustang Odometer Gear Repair Kit by Odometer Gears at LRS - Same Day Shipping!
That should fix it.
I'm red.
Old January 27th, 2012, 12:07 PM   #5
1996 GT - why would you ask if it was a 5 speed after answering a question about the clutch 3 lines prior? Hahahaha.
O o
\_\
Old January 27th, 2012, 01:00 PM   #6
im not slammin gears all the time. its even hard to find 1st sometimes. I have to jam it in and it sucks. it has an old steeda shifter that is like loose. it doesn't like rest in one area i can move it around like its sloppy..
Old January 27th, 2012, 01:24 PM   #7
Traction...?
1996 GT's Avatar
LOL opps! It was early in the morning here and i just woke up.
Then wondered into the garage for three hours reassembling the stang.....
http://www.americanmuscle.com/t5-t45...t-shifter.html
I just put one of those in my car. Its very nice for the price. No slack or anything but before you go buying a new one take yours apart and make sure every things tight, and if it isnt, make sure you use red lock tight.
Old January 27th, 2012, 01:36 PM   #8
Pseudo-Newbie
Long Stroke's Avatar
1990 Mustang
8.903 @ 152.99
Long Stroke is on a distinguished road
If your the original purchaser of the shifter I'll fix it for free or you want us to rebuild it I would be more then happy to.
Scott@Steeda.com
Old January 27th, 2012, 01:59 PM   #9
i bought it from my neighbor. I mean if i needed to i can have him ship it lol. Can i still take you up on the free offer? Where do i send it?
btw this forum is pretty awesome. I have a fully built vortech 2003 hyundai tiburon and the forums for that are slow.
Old January 27th, 2012, 02:06 PM   #10
Should be part of the Steeda warranty/guarantee. You would ship it back to them.
Of course, you'll need to have another shifter while yours is being rebuilt or you won't be able to drive the car.
O o
\_\
Old January 27th, 2012, 04:35 PM   #11
Pseudo-Newbie
1990 Mustang
8.903 @ 152.99
It only applies to the original purchaser but I'm the one that accepts or rejects all the Steeda Manufactured parts so I'll let this one slide
Send it back to the following.
Steeda (att: Scott Boda)
2019 Steeda Way
Valdosta, GA 31601
RGA#MODMUSTFRM
I'll fix it and get it shipped back out to you in 1 day.
Scott@Steeda.com
Old January 27th, 2012, 09:15 PM   #12
Awesome. Thanks Scott!!
Old January 27th, 2012, 09:45 PM   #13
Just Another Stang
1996 Mustan GT
N/A
Qwik96 is on a distinguished road
Wow, you guys are really helpful & generous for a fellow Stang member in need!!! Great job! Good to know that these type of people still exist! Class act guys!!!
Old January 30th, 2012, 09:56 AM   #14
Pseudo-Newbie
1990 Mustang
8.903 @ 152.99
Thanks for the kind words.
1Badtib I'm keeping my eye open for your shifter.
Scott@Steeda.com
Old January 30th, 2012, 01:32 PM   #15
delgadog's Avatar
1997 Mustang GT
None yet...
delgadog is on a distinguished road
damn long stroke, i wish i would have known that about sending in my old tri-ax! grrr... got rid of it and got a pro 5.0 which was so nice sorry to thread jack, i digress.lol.
95 GT - nothing stock on her R.I.P.
97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake
comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot.
Old January 30th, 2012, 01:47 PM   #16
Pseudo-Newbie
1990 Mustang
8.903 @ 152.99
Sorry to hear that delgadog. All of Steeda's parts carry a lifetime warrantee.
Scott@Steeda.com
Threads Similar to: new to mustangs.
Mustangs & Mustangs Show ZoomZoomMFer The Clubhouse 1 November 29th, 2010 05:20 PM
13th Annual Fantasy of Flight Mustangs and Mustangs Mr.Stang08 Southeast 4 April 12th, 2010 04:28 PM
fav car besides mustangs? 08blkgt500 The Clubhouse 47 October 25th, 2009 09:41 PM
Mustangs for Mustangs Car Show Roushed2 Southeast 2 October 8th, 2008 03:14 PM
