1996 Overheating Issue?
Old January 25th, 2012, 08:59 PM   #1
Just Another Stang
1996 Mustan GT
N/A
Qwik96 is on a distinguished road
I have read on here in a few threads that people mention an overheating problem in the 1996 models, but was corrected in 1997... Can someone please enlighten me as to what the problem is & what is the fix? My car has under drive pulleys which I heard may cause the temp gauge to read slightly higher than normal, but other than that nothing is wrong!
Old January 25th, 2012, 09:06 PM   #2
BigSmith is on a distinguished road
My NPI intake manifold was cracked and leaked out all my coolant and sent my temp up one day.. it would be a good thing to check
Old January 25th, 2012, 09:26 PM   #3
96-GT_Josh is on a distinguished road
I got a 96 with 198k miles on it. Its been in the family since 40k something miles and its never had any overheating issues and still shows no signs yet.
But like stated keep an eye on the plastic manifold.
Old January 26th, 2012, 09:44 AM   #4
1996 Mustang GT Vert
Blower Head is on a distinguished road
I think what happened was they held over the radiator, ac condenser etc from the 95 model with the 5 liter. At one time there was a retro-fit kit from ford to correct the problem. I have heard this in not available anymore. I had the issue and corrected it with a high-flow water pump and a Fluidyne radiator.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old January 26th, 2012, 10:14 PM   #5
1998 Mustang GT Convert.
drakkhen20 is on a distinguished road
yes I would agree with blower head, go to the junk yard and find a 98 radiator and fan and youll be fine. also in that year you may still have the intake thats fully plastic and doesnt have the aluminium crossover pipe. you can find these intakes everywhere as well. drain your fluid out, take the hoses off and stick a water hose in top and run it til the water turns clear again, do the same with the radiator and go buy some prestone antifreeze and whatever they call it I think its "wet stuff" or something like that and youll be fine. also if you change your water pump order another for a cobra 4.6, it comes with a housing around the impellars that move the water and promotes less cavitation in your system. another thing, when you buy a thermostat make sure it has a little hole in the plate that opens to let the water through, if it doesnt drill one no bigger than the lead in a pencil. this hole lets your system get the air out and tiny bubbles lingering around. hope this helps.
95 Mustang GT 5.0L
Old January 26th, 2012, 10:20 PM   #6
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
Like people said, I think our 96's have radiators that are bad.
Old January 27th, 2012, 03:29 PM   #7
Just Another Stang
1996 Mustan GT
N/A
Thanks for the help! I'll definitely be on the lookout for any signs... But if I do the 4.6 PI swap then do I still need to be concerned?
Old January 27th, 2012, 03:32 PM   #8
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
I would still go ahead and do the whole rad swap n everything if it were me. Doing the PI swap will take care of the plastic intake though, so that's good.
Old January 27th, 2012, 09:36 PM   #9
Just Another Stang
1996 Mustan GT
N/A
So new stock radiator or aftermarket & new high flow aftermarket water pump...?
Old January 27th, 2012, 10:06 PM   #10
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
?huh?
I would just get a 98 radiator & fan, and do your PI swap. Doesn't have to be aftermarket.
Threads Similar to: 1996 Overheating Issue?
Overheating Issue!!! Need Help 9848mustanggt 96-98 22 January 4th, 2012 05:21 PM
Overheating issue mgiara 2005 - 2010 17 December 23rd, 2011 10:57 PM
Intake manifold issue or head issue? sledgehammer357 All Other Vehicles 2 July 20th, 2011 01:58 AM
1996 GT to 1996 Cobra White96reborn 96-98 8 September 10th, 2010 09:47 AM
1996 4.6L SOHC Block vs. 1996 DOHC Block mustangman36578 96-98 3 March 27th, 2007 03:36 AM
