p0401
Old January 28th, 2012, 07:14 PM   #1
brandywine112972's Avatar
1997 mustang gt
brandywine112972 is on a distinguished road
p0401
this code is driving me nuts. it comes and goes. be on for a few days, then goes off for a few days. ughhh. it is an egr flow insufficient. need help on where to start. thanks in advance folks.
if at first you don't succeed, try a bigger hammer.
it if doesn't fit, force it. if it breaks, it needed replacing anyway.
Old January 28th, 2012, 07:32 PM   #2
MikeHP350's Avatar
1998 Mustang GT Conv.
MikeHP350 will become famous soon enough
Send a message via AIM to MikeHP350
DPFE sensor
CAI, 75mm TB/Upper intake Plenum, Shorty Headers, Catted H-pipe, Flowmaster 40's, STEEDA U/D Pulleys, Sniper SF 93 Oct. Tune. MSD Coils/8mm Wires, NGK Iridium plugs, Full PI swap H/C/I, STEEDA adj. clutch cable/quadrant, RAM HDX Clutch.
Old January 28th, 2012, 09:33 PM   #3
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
Do you hear anything around the egr when you step on it? I had one with a bad dpfe and it kept blowing the hose off. It was very noticable.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old January 28th, 2012, 10:48 PM   #4
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
If you're dpfe sensor is made of metal, more then likely your problem because of that being the one it came with from the factory. If its plastic someone has swapped a newer one on at some point.
Threads Similar to: p0401
p0401 moosenuk17 99-04 2 November 2nd, 2011 07:24 PM
P0401 (egr valve?) code after installing Long tubes.. tbmd 2005 - 2010 0 June 24th, 2011 01:52 PM
code P0401 kells14u2 V6 Mustangs 4 January 27th, 2011 09:17 AM
DTC Code P0401 StubzStang V6 Mustangs 1 September 11th, 2010 04:15 PM
Threw a P0401 00SoSlow V6 Mustangs 7 June 30th, 2006 12:10 AM
