1996 Mustang Gt
9.9033@70.85 1/8 in rain(Stock)
steering squeak help!!!
Need help can not figure out what is causing this horrible squicking I get randomly when I turn the wheel. Ive already put it on jacks and as soon as I turned the wheel It stops squicking, it only squicks on the ground. My wheel bearing is bad and front springs were welded together by previous owner. Could this cause it? I have a new bearing/ lowering springs on order also. Don't mind how dirty my car is its winter(snow tires ftw). She will get a full detail when its nice.
Here is a vid hopefully someone can help
![]() Pacific Green 96 Gt |
1997 mustang gt
sounds like ball joints to me.
if at first you don't succeed, try a bigger hammer. it if doesn't fit, force it. if it breaks, it needed replacing anyway.
'99 GT 35th Anniversary
14.266 @ 103.41
Outer tie rods. Mine sounded the same.
SMR #2043 |
1996 Mustang GT Vert
![]() iTrader: 1 reviews
+1 on the ball joints. Mine sounded like that.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's |
1998 Mustang GT
![]() iTrader: 2 reviews
ball joints. jack tge front of your car up so that theres a couple inches between the tires and ground. take a big pry bar and pry up from under your tires. if you feel any play the ball joints are bad. but they could also squeak without play. mine did that last year
pi swapped and dropped sn95 |
1996 Mustang Gt
Already replaced both outer tie rods. Thank you guys I just found another vid of a stang with the exact same squicking. Now I need to replace my ball joint, wheel bearing and springs fun day for me
1997 mustang gt
if you want to, you can come do mine when you're done
Traction...?
1996 GT/ 2008 GT Vert
^ I second this, i have a brand new set of springs that need to be put in.
Threads Similar to: steering squeak help!!!
| Stupid squeak squeak | KV007 | 99-04 | 3 | December 2nd, 2011 11:34 PM |
| Stupid squeak squeak | KV007 | 99-04 | 5 | August 8th, 2011 06:36 PM |
| Isolators: Squeak or no squeak? That is the question. | freefallin2000 | 99-04 | 22 | April 12th, 2010 11:47 PM |
| Power steering pump or pulley squeak | Rush | 94-95 | 4 | November 17th, 2009 09:26 PM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
