1996 GT stuck in reverse.
Old January 29th, 2012, 08:23 PM   #1
More show than Go
azure mach!'s Avatar
2003 mustang mach 1
azure mach! is a jewel in the roughazure mach! is a jewel in the roughazure mach! is a jewel in the roughazure mach! is a jewel in the rough
Can anyone tell me what could possibly do this ?
manual tranmision by the way.
2000 trans am ws6 - Rest In Pieces
2003 Mach 1 - Weekend Warrior
1998 taurus - DD
Originally Posted by Jazzer The Cat View Post
I have never sucked donkey balls
ok... just once though
Old February 2nd, 2012, 12:07 PM   #2
1998 mustang gt
c-for is on a distinguished road
there is a tsb on this concern
Article No.
01-23-5
11/26/01
TRANSMISSION - T-45 MANUAL TRANSMISSION -
STUCK IN REVERSE - DIFFICULT TO SHIFT INTO
REVERSE - POPS OUT OF REVERSE
FORD:
1996-2001 MUSTANG
ISSUE
Some vehicles equipped with the T45 transmission may exhibit a condition of being stuck in reverse, difficult to shift into reverse or may pop out of reverse. This may be caused by the 5th/Reverse Gear Shift Fork. This article does not apply to the condition of "unable to get into reverse" or "reverse block out".
ACTION
Verify which shift fork is in the transmission, measure the reverse engagement, and replace the shift fork with the proper part number. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Please follow the procedure in the appropriate Mustang Workshop Manual, for the T45 transmission removal. Refer to the appropriate section in that Workshop Manual for the disassembly of the transmission. In this section, complete the steps up to and including the removal of the Fifth/Reverse Synchronizer Sleeve, the Fifth/Reverse Gear Shifter Fork and the Reverse Synchronizer sleeve. After this is complete, continue with the following steps.
1. While viewing the extension housing from the front, place a small amount of standard modeling clay on the reverse idler bracket (7723) near the 5th/reverse shift rail support. hole (near the exterior wall of the housing Figure 1).
2. Place a standard 9/16" hole diameter plain washer on the 5th/reverse shift rail and against the rear face of the 5th/reverse shift fork. The washer is placed behind the fork as installed on the rail.
3. Re-install the extension housing (7A039), offset lever (7F018), spring (7E172), ball (7234) and roll pin (35749-S15). Attach securely with only two (2) bolts.
4. Attach the shifter assembly (7A039) securely and (with the appropriate upper lever) make a high effort, quick shift into reverse.
5. Remove the extension assembly (7A039) as before and conduct the reverse engagement inspection.
6. Using an appropriate depth gage, carefully measure from the case mounting face of the extension housing to the face of the plain washer, which should be stuck in the modeling clay. Take three (3) readings and calculate the average. This is the measure of reverse engagement.
7. Using the following criteria, select the correct 5th/reverse fork. This fork should replace the current fork in the transmission.
a. If the measurement is less than 68.1158 mm (2.682 inches), use the "long" fork (F8ZZ-7230-EA).
b. If the measurement is greater than 69.233 mm (2.726 inches), use the "short" fork (F8ZZ-7230-DE).
c. If the measurement falls between the above values, then install the "nominal" fork (F6ZZ-7230-C).
8. Remove and replace the current fork with the new fork, per the Workshop Manual procedure.
9. Clean the joint surfaces of the castings (main and extension housing) and shifter.
10. Re-assemble per Workshop Manual.
11. Verify repair
Parts Block
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
012305A Replace The Reverse Shift 3.6 Hrs.
Fork (Includes Time To
Remove, Disassemble,
Measure And Reinstall
Transmission)
DEALER CODING
CONDITION
BASIC PART NO. CODE
7230 42
OASIS CODES: 505000
Old February 2nd, 2012, 12:28 PM   #3
More show than Go
2003 mustang mach 1
We ended getting it out of reverse, but i'm sure it'll happen again and i'll use what you put. Thanks man ! Reps by the way
1998 taurus - DD
Old March 13th, 2012, 08:41 AM   #4
dylan96mustanggt is on a distinguished road
my 96 mustang gt recently got stuck in 1st and turns out it was the piece that grabs the shifter fork had snapped and if that happens your looking at around 300 for replacing
Old March 13th, 2012, 05:05 PM   #5
philly101's Avatar
96 gt vert
philly101 is on a distinguished road
lol I have this happen when backing n to a parking space wha made it even horses I was also on my first date lol got it out 15 min latter
Just a few moddes 2 in drop ksport an MAC cat back pi intake an siting on 17x11
Old March 14th, 2012, 09:08 AM   #6
ha that sucks man! about a month ago i was trying to park and couldnt get my car to go in reverse for at least 10 mins
Threads Similar to: 1996 GT stuck in reverse.
Help! Stuck In Reverse!? JasonT1124 99-04 11 July 7th, 2009 11:21 PM
Cant Move! Car is Stuck In Reverse! 96cobra201 V6 Mustangs 11 April 28th, 2009 03:12 PM
car gets stuck in reverse phorkinator 99-04 1 April 5th, 2009 05:14 AM
Reverse is stuck RyanGT 99-04 19 March 9th, 2009 09:39 PM
OMG i'm stuck in reverse! knightof206 Modular Mustangs 8 October 12th, 2008 11:32 PM
