Cracked timing cover!
I was going to change my tensioner on my car and i noticed a little crack, so i pulled the valve cover and saw that the cover had about a 2 inch crack in it. i tried Americanmuscle.com but couldt find one on there. i am wanting to get a new one with gasket. and also where could i find a service manual or something like that, that will show most of the torque specs for the car. My car throws a belt sometimes when i get on it and it'll detonate at 5k rpms and has a pretty bad idle surge sometimes. i was told that my tensioner looked a little bent and was going to replace it, then take it down to Strictly performance and have them tune the car. The car has stage 2 or 3 cams and vortec supercharger and i list done to it. any advice would really help! i mainly need to know where to buy a timing chain cover! Thanks
3.55 gears, Cai, magnaflow exhaust, advanced timing to 12 degrees,underdrive pullies, throttle body spacer, plenum intake spacer, BBK o/r H-pipe, king cobra clutch....havent gone to the dyno, more to come |
You'll need to get a used 1 check the yards and ebay
MM FOBRA CLUB MEMBER #1 |
1997 Mustang GT
I got one from a 2001 mustang $50 if u still looking.
Rollin' 18/ pushin' 2
You don't know what cams you have?
Hooo Ha Ha
I have one if your interested
![]() 410rwhp 520rwtq @ 12.9 psi |
i didnt have the car when the cams were put in. but im pretty sure they are stage 3. and whats the easiest way to replace the timing cover? Take both valve covers off? or any suggestions? and what about the idle surge and detonation at 5k?
I have the receipts for the work done and can see what all is done to it lol.
1996 Mustang gt
I think you need a better tune. Maybe some timing work to retard the detonation. The idle surge could be anything from a TPS, IAC or vacuum/intake leak.
Threads Similar to: Cracked timing cover!
| timing cover cracked. need replacement? | VM0824 | 5.0 Mustangs | 3 | December 12th, 2011 09:06 AM |
| cracked timing cover..... | deadbeat | 99-04 | 10 | June 27th, 2010 11:48 PM |
| Cracked Fuel Rail Cover?? | Mustangshar | 2005 - 2010 | 0 | June 21st, 2009 02:07 AM |
| Cracked Valve Cover | winnie51189 | V6 Mustangs | 10 | March 4th, 2009 03:17 PM |
| Cracked cowl vent cover | ndfrspd | 96-98 | 12 | October 23rd, 2008 04:08 PM |
