Lock cylinder malfunctioning
Old February 2nd, 2012, 01:52 PM   #1
BigSmith is on a distinguished road
Im looking for a replacement lock cylinder for my 96 mustang gt.
Would this one work??
Standard Motor Products US175L - Standard Motor Ignition Lock Cylinders - Application - SummitRacing.com
Im thinking this is the one for a foxbody...
Old February 2nd, 2012, 04:33 PM   #2
1996 Mustang GT Vert
Blower Head is on a distinguished road
It looks like it only goes through 95. Would be an issue with pats. What is wrong with your present one.
96 GT vert, Aftercooled Vortech, Lightning MAF,42# injectors, saleen cams, Bullitt intake, tune by Hitech, Magnaflow catback and O/R xpipe, Cobra brake upgrade, lowered bilstein suspension w/MM c/c plates and subframe connectors 3000 stall and 3.73's
Old February 2nd, 2012, 07:06 PM   #3
My Key is dull so it wont engage in the tumbler very well so i have to jiggle and jank around the mechanism until it engages and its a pain..
Ford doesn't have the key schematics after 7 years. They get rid of them. So i can't really get a new key cut because my old key sucks. And ford wants 200 bucks for a new tumbler and 300 bucks to get the tumbler cut and a key for it...
If i can find an aftermarket tumbler with a programable chip i could get it fixed for 100 bucks but i can't seem to find one. The Tumblers are like 50 bucks and the key is like 30 to program at a locksmith... Can i get a new key cut to match my tumbler, rather than the old key?
Old February 2nd, 2012, 07:52 PM   #4
Rollin' 18/ pushin' 2
97S281's Avatar
1997 Saleen S281
iTrader: 13 reviews
I have seen that done on tv. Call a locksmith and get a price. I guess as long as you have your pats key close to the non pats key it would still work. Sounds ghetto but you could tape your pats key to the bottom of the column and use the other one.
MODS IN GARAGE
NCMM ORIGINAL
BLOWN 96-98 CREW MEMBER # 1
Old February 2nd, 2012, 08:15 PM   #5
A good locksmith could make you a key. Then order a new chipped key off of ebay and get it cut from the one that the locksmith made then program it in.
Old February 2nd, 2012, 10:16 PM   #6
Can they make a key just from my tumbler? Because then i guess i could just get a Chip key and give them my tumbler then they could go from there. I think they can also just use my old chip and copy the code onto a new one.
Old February 3rd, 2012, 06:36 PM   #7
I do not think they can copy anything to do with the chip. The danger might be if they screw up with just a plain blank it is not a big deal cost wise. If they do it with a chipped key it gets more expensive.
Threads Similar to: Lock cylinder malfunctioning
Ignition Cylinder Stuck in Lock Position - 01 Mustang BCohee V6 Mustangs 3 February 25th, 2011 11:47 AM
1998 ignition lock cylinder BBMUSTANG V6 Mustangs 0 July 25th, 2010 01:51 PM
85 ingition lock cylinder swap Spike Digidy! 5.0 Mustangs 2 July 12th, 2010 07:48 PM
99 3.8 lock cylinder problem woodads V6 Mustangs 4 May 18th, 2010 02:38 AM
Hatchback Lock Cylinder Removal imported_Gt_Jay 5.0 Mustangs 5 December 9th, 2007 12:47 AM
