New to fords doing PI intake swap
I'm new to fords as well as modular engines and will be doing a PI intake swap. I have a FRPP intake with the aluminum cross-over. I've seen people say use NPI gaskets and others say use PI gaskets. If the experts on the matter could clarify it for me so I don't have to do this more then once. Thanks.
#2 | |
This is a good article on it and there is also one on the forum here. ModularHeadShop Articles on PI intake swap Heres the link for the one on the forum however there are no pictures. This swap is really easy and it really livens up the NPI motor. It lets it breath waaaaay past 5,000rpm. Mine seemed to choke out after 4800 now it pulls waaaay further up the rpm range. A fantastic mod!! NPI to PI Intake Swap... The most important thing is letting the RTV set properly. Make sure it sits for 24 hours!!! |
1997 Pacific Green Cobra
14.80 No traction
Most def. you will enjoy the intake. i suggest going straight to a different cam. such as Hitech stage 2 or CMS stage 1 for a simple install. Neither require new springs, both make a nice lope and you won't have to worry about doing a swap twice when you get tired of P.I cams lol. Mine got old fast , but im pulling the most out of it through a stock Torque converter.
On the intake swap do use the P.I gaskets and let that RTV sit 24 hours. I did mine, about to redo it soon because after 15k on it i have a slight leak . I used red RTV but i think the black or blue might be better. Not too sure. someone should coin in on that.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
I'm not used to a stock vehicle so the lack of top end pull is kind of getting to me. I found the heater tube for $80 at ford but no luck on the nipple. So far it has been one of the least expensive mods I'll have done. I just need to find the nipple so I know everything is done correctly. With the silicone I've read the copper is the best. I may have read wrong so any clarification on that would be wonderful.
1998 Mustang GT- 4.6 2v, 5spd. FRPP PI intake MAC 2.5 to 3.5 cat back exhaust MSD coils and wires Fenderwell CAI Strut tower brace |
I got lucky and found the PI nipple at ford. The part number is F75Z-8555-AA I was quoted $11 so it will be money well spent to do it right.
14.80 No traction
when i did mine i did not need the new nipple. not sure why but it was upgraded already lol.
Thats really weird lol. Is that a 96? My 96 had this small metal pipe with a flange on the end.. No o rings or anything
96 gt, 5 speed manual, BBK off road X pipe, Magnaflow Magnapack catback, BBK CAI, PI intake swap, B and M Pro ripper shifter, 4.10 gears, 180* thermo
14.80 No traction
its a 97. I believe when the motor was in my parents car they had the intake replaced. so ford may have done this once before. I just went ahead and stuck the new coolant pipe in there and all is good.
see.
Threads Similar to: New to fords doing PI intake swap
| okay now im mad...intake swap ?'s | projectGT | 96-98 | 42 | December 27th, 2011 10:49 AM |
| pi intake swap | brandywine112972 | 96-98 | 12 | November 5th, 2010 08:58 AM |
| Intake swap Q's | sickfox | 5.0 Mustangs | 14 | March 6th, 2010 10:25 PM |
| PI intake swap run-through | 2000Mustang | 96-98 | 0 | November 3rd, 2008 09:52 PM |
| 95' Mustang 5.0 HO intake swap for 93 cobra intake... | stang9587 | 5.0 Mustangs | 1 | April 3rd, 2007 05:20 AM |
