1997 Pacific Green Cobra
14.80 No traction
my 4v engine 6 bolt main
Ok this is my noob question of the day. I have the 4v teksid motor. they say 6 bolt mains but what exactly is meant by this. Is it the number of bolts on the crank caps ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
Nah I believe that means 6 bolts for the flywheel and 8 bolt flywheels like newer cobras and GT's. Not sure exactly what years the changes were made though. But SN95's I believe are all 6 Bolt.
14.80 No traction
thanks but i found the answer. It is the 6 bolts that cap down the crank shaft. It is not the shaft bolts itself. I went ahead and reviewed everything. But im about to remove the pistons and stuff and work the block .
There are 6 main cap bolts on the skirted relapses blocks. Crank if cobra is 8 bolt or mark cast crank is 6 bolt
MM FOBRA CLUB MEMBER #1 |
Teksid block*
14.80 No traction
Yeah i have a forged crank. looking to some ungodly RPM haha.
What parts do you need i have some cobra parts
14.80 No traction
only thing i need is the cobra intake and stock exhaust headers. Not going to go with aftermarkets. Everything else is being custom spec down to the tranny. Im on the B heads of course. And im going to be spitting about 7500 rpm if things go right. Getting lined up atm. Things are looking good
Which is why i have had good reason to putting cash into the body of the car itself. (rear ect) to support upcoming powuz haha.
You going to use mark cams? Why so high rpm?
14.80 No traction
nahh custom grinds and rpm to take advantage of the low gears as much as possible. and im getting a good deal
Threads Similar to: my 4v engine 6 bolt main
| 351w 4 bolt main, what c4? | stang67coupe | Classic Mustangs | 8 | January 21st, 2010 03:02 PM |
| is a 4.6 sohc a 2 or 4 bolt main? | busaonboost | 96-98 | 3 | June 7th, 2009 04:59 PM |
| is a 2 bolt main enough? | usmcsawgunner | 5.0 Mustangs | 5 | February 7th, 2008 07:17 PM |
| is there a way to te bolt main from the year? | DJKING | 5.0 Mustangs | 1 | April 9th, 2007 04:34 PM |
