94 Mark VIII swap into 96 GT
Old February 4th, 2012, 04:46 AM   #1
apaulk86 is on a distinguished road
Hey there, I'm a new member, but have read many threads in the last year on this forum. A few months ago I purchased a dohc 4.6 out of a 94 Mark VIII, wanting to drop it in my 96 GT. I have read much conflicting information, but want to get a solid answer from someone who knows. As you know, the Gen I mark engine I have has the intake with the throttle body on the rear of the intake, close to the firewall. I don't have the cash to buy a cobra intake like I want, but want to stick with a mark intake for now. WILL this intake fit into my car without the firewall obstructing the placement of the motor? If it will fit, the only thing I need to buy is some cobra exhaust manifolds or splurge for headers, and I can drop it in. PLEASE HELP! I need this info, because I'll get started on the project ASAP if I can. Thanks!
Old February 4th, 2012, 08:57 AM   #2
96-GT_Josh is on a distinguished road
The motor will fit and is actually better for the 96-98 because the 2 coolant sensors in the corssover and the plug wire set-up valve covers. I have read that the Gen 1 intake mani flows better than the Gen 2 intake mani as well.
And there have been some people on here that have used the Gen 1 manifold and got the engine in fine. But I do not recall if there was any modifications needed to the firewall cowl area to make it clear.
Hope that helped a little. Just go for it if the price is right. You can always get the Gen2 intake manifold from a pull-it yard if you cant make the Gen 1 fit. Should only cost a couple dollars.
Old February 4th, 2012, 10:35 AM   #3
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
Just buy a mark 8 gen 2 intake you can prolly get 1 for under a hundred the gen 1 intake will be a bitch
MM FOBRA CLUB MEMBER #1
Old February 4th, 2012, 02:24 PM   #4
1998 Mustang GT
13.046@107.49
cruizer will become famous soon enough
Seems like I've seen someone get a gen 1 Mark viii intake to fit with like almost no room against the firewall. But you also have to remember that the throttle body points up so you are going to be running and intake tube going over the manifold. This increases the height of the engine. Without a hood scoop it won't fit
98 Mustang GT 13.795 @ 98.87 N/A
Main mods: PI Swap, 3.73 gears, E85
My Mark VIII and T56 swap
Old February 4th, 2012, 04:36 PM   #5
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
+1. not the best way to go about it but it would give a nice excuse for a cowl hood. i would look for a later Lincoln Mark VIII manifold. you can get those for cheap and it will have the TB inlet on the passenger side. if you need one, i actually do have one...its dirty and would need THOROUGHLY cleaned but i would let it go CHEAP. like $50 +shipping to you.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old February 4th, 2012, 06:03 PM   #6
p4ndiamond's Avatar
1997 Pacific Green Cobra
14.80 No traction
p4ndiamond will become famous soon enoughp4ndiamond will become famous soon enough
i have a gen 2 intake from a 98 . throttle body and all. im going to replace it with a cobra intake.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA "
Old February 5th, 2012, 11:28 AM   #7
The cowl hood is not an issue at all. I actually bought the car last year with a giant hood cowl. I am just looking for the best method to accomplish this task. I have gone to the salvage yard MANY times looking for a gen2 intake and have not been able to find one. There is actually a gen 1 mark viii at the yard right now, and I could get the throttle cable from it since I've read that my stock GT won't be compatible. If I do buy a gen 2 intake, I'll need the throttle cable with it too.
Old February 5th, 2012, 11:32 AM   #8
LGHTNG02GT, I will definitely keep you posted on what I decide to do. It may end up being better for me to pick up that intake from you. All I know is that my current 2v is TIRED and burns oil if I do not keep like a 70/30 ratio of Lucas oil stabilizer in it.
Old February 5th, 2012, 01:44 PM   #9
1989Gt.'s Avatar
1989 Mustang GT
It's going to be a pain bottom line with the gen 1 intake plus its a pos
Old February 5th, 2012, 05:32 PM   #10
4vGT's Avatar
1997 4v Mustang GT
13.66
4vGT is on a distinguished road
Send a message via AIM to 4vGT Send a message via Yahoo to 4vGT
Heres my list
Nicks 1997 Ford Mustang GT
Mark VIII 4v Motor Install
Parts and Mod Guide
NEW PARTS REQUIRED:
1994-1998 Lincoln Mark VIII 4v motor, complete long block
1997-1998 Lincoln Mark VIII Intake and throttle body
1997-1998 Lincoln Mark VIII Throttle cable
1994-1998 Lincoln Mark VIII Fuel Rail
1994-1998 Lincoln Mark VIII Alternator
1991-2004 Ford 4.6 Motor Mounts- Mustang/Cobra
1994-1998 Lincoln Mark VIII water crossover and thermostat housing
1994-1998 Lincoln Mark VIII/ 96-98 Cobra IAC
1996-1998 Cobra IMRCs/1997-1998 Lincoln IMRCs
1996-1998 Cobra spark plug wires
REUSED PARTS REQUIRED:
Mustang GT power steering pump
Mustang GT AC pump
Mustang GT Flywheel/Clutch or Flexplate
Mustang GT starter
Mustang GT fuel injectors
Mustang GT wiring harness
Mustang GT MAFS
Mustang GT radiator
Mustang Ignition coils (COPS if later model GT is used)
NEW MISC PARTS:
1 clay pipe 4”-3” reducer
1 4” OD 90* elbow
1 4” OD to 3” OD reducer
2 universal 90* PCV valves
Hoses as needed
Originally Posted by VaporS197 View Post
You're a good guy, 4vGT!
Old February 5th, 2012, 10:59 PM   #11
Originally Posted by 4vGT View Post
Heres my list
Parts and Mod Guide
NEW PARTS REQUIRED:
Mustang GT AC pump
Mustang GT starter
Mustang GT MAFS
Mustang GT radiator
NEW MISC PARTS:
1 4” OD 90* elbow
Hoses as needed
4vGT,
What kind of tuning did you get? I've been told to get an e-mail tune, or even go to a dyno shop and have them tune it.
Old February 5th, 2012, 11:20 PM   #12
Robs4valve's Avatar
96 gt, 4 valve
Robs4valve is on a distinguished road
Originally Posted by apaulk86 View Post
4vGT,
For the tune I would call Willie at dirtydirtyracing.com he will set you up with a tune to run the 4v on your 2v computer. If you buy a SCT tuner or delta force tuner, he will send you a tune based on what ever you have done to the car.
His tune shaved a full second off my 1/4 mile time on my mark 8 swap.
Just my .02 on the tune.
Robert
96 Gt, 4v swap....Burns gas and rubber!!
Building; 98 Teksid, Manly 11cc pistons, Manly H beam rods, 98 forged crank, ARP throughout, C heads with a little exhaust porting and 98 cobra cams, 76mm PTK/custom turbo......Still just burns cash!
Old February 6th, 2012, 05:23 PM   #13
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
I too went with email tuning for my car. i however went with Amazon Tuning Solutions in South Carolina. Rick there really knows what he is doing when it comes to tuning Fords
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old February 6th, 2012, 05:31 PM   #14
4vGT's Avatar
1997 4v Mustang GT
13.66
4vGT,
If you reuse your MAFS and injectors, nothing needs to be changed.
IF you change your injectors, delete smog, or anything else, BAMA can tune it with a mail tune, but they dont like to hear you have a motor swap on a GT ecu as they dont have a program written for it-
Best way to tune is to take it somewhere.
Old February 9th, 2012, 03:25 AM   #15
1989Gt.'s Avatar
1989 Mustang GT
Really they dont like swapped engines?
Old February 9th, 2012, 06:36 AM   #16
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
i never even considered them when it came to tuning my car. i had it down to two or three guys. one being Joe at Trick Tuners, the guys at SGS performance (a shop here in PA) and then Rick at Amazon. untimately after speaking with Rick on the phone, i decided to go that direction and never looked back.
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old February 9th, 2012, 02:44 PM   #17
POWA! 24/7 fukkers
V8POWA!'s Avatar
1 @ 1
V8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of lightV8POWA! is a glorious beacon of light
ahhh I wanna do a swap already!
Old February 20th, 2012, 09:35 PM   #18
LGHTNG02GT,
Will you send me an email to discuss the gen 2 intake you have? I haven't posted enough on here to send a pm. You can reach me at a.kamp86@gmail.com
Thanks in advance
Threads Similar to: 94 Mark VIII swap into 96 GT
Mark VIII Swap question... HurrycaneStang 99-04 26 April 10th, 2012 04:45 PM
4.6 Mark VIII DOHC swap reflexr 2005 - 2010 V6 1 May 4th, 2011 10:03 AM
Need some headers of my mark viii swap. Speedy1221 4V / SVT 9 July 26th, 2010 02:40 AM
few mark viii swap question. Speedy1221 99-04 12 July 23rd, 2010 05:02 PM
Lincoln Mark VIII to 04 GT swap Straits15204 99-04 7 June 17th, 2008 05:04 AM
