#41 | |
1997 Pacific Green Cobra
14.80 No traction
If you go with a cam that needs springs i suggest these . Unless you plan on going with some crazy cams in that bad boy...or girl hahaComp Cams Mustang Valve Springs Kit Beehive (96-04 4.6L 2V) 26113-16 - Free Shipping!
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
#42 |
1997 Mustang GT
the $$ keeps adding up haha. So stage ii cams, intake mani, new valve springs and retainers? but the stock cam gears will work right?
If i go with the Comp Cams will i need new valve springs? Or is it one of those things where its better safe then sorry..
![]() Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012) Last edited by WhiteNoise; February 6th, 2012 at 11:55 PM. Reason: new |
#43 | |
14.80 No traction
You would then need adjustable cam gears or adjustable crank sprockets. Trick Flow Specialties TFS-51800505 - Trick Flow® Replacement Adjustable Crank Sprockets - Overview - SummitRacing.com They are so you can retard and advance the cam . If you do hitech stage 2 cams then you only need the cams and these gears. Not even springs or retainers ect.
#44 |
1997 Mustang GT
and hitech means like the Comp Cams. So if i go with stock cams from 01+ ill need springs? Or stock ill need sprockets and Comp Cams ill need springs? I keep getting more and more confused
![]() Mods: MAC o/r H, SCT tuner, CAI, short throw shifter, dash LED conversion Upcoming: Suspension build (Spring/Summer 2012) |
#45 |
14.80 No traction
Haha no. You can go with any cams. But i suggest the Hi Tech they make the most power . Comp is a company that makes many grinds of cams. When i say Hi Tech thats what i mean lol. You don't need springs with them . springs are recommended for the cam as they can make power over 6500.. i don't suggest running that high without aftermarket springs. But they are not required anyhow.
This http://www.hitechmotorsport.com/perf...category_id=65
#46 |
1997 Mustang GT
Well i decided to go with stock cams because cams are out of my price range right now. But with the stock cams, will i need those adjustable cam gears? or should the stock just bolt right up?
Being that mines a 97, it should have the plastic crossover, so i can reuse it, correct? (My care is not with me, which would make alot of this easier!!) And i've read alot about the 180 thermostat, should i get one? I can only find them for 5.0 and v6's. http://www.americanmuscle.com/180-thermostat-7995.html
#47 | |
14.80 No traction
Don't use the plastic cross over its crap and cracks . Honestly im on a 192 thermostat and it runs its best with it. The 180 is a prime choice but after much driving aand testing i got the best results out of the 192 stock thermostat . but a 180 is fine if where you are if overly hot.
#48 |
1997 Mustang GT
His intake should come with the aluminum cross over then? (03 GT) Will i need to drill it then?
#49 |
14.80 No traction
It should and you can. Drill and tap for the gauge cluster to operate.
Threads Similar to: PI head swap
| head swap ??? | Tank86 | 5.0 Mustangs | 11 | March 8th, 2011 08:41 PM |
| PI head swap | wheelsjz | 96-98 | 12 | October 6th, 2010 07:37 PM |
| 4.6l head swap to 5.4l head. (questions) | 9-d-9 cobra | 4V / SVT | 72 | May 19th, 2010 11:59 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 4 v head swap | finaly03vert | 99-04 | 9 | October 3rd, 2007 12:19 PM |
