96 mustang gt
5.4 swap, need help please
Ok, this is a question for the guys who know info about the 5.4 swap. I really want to do the swap on my 96 gt. The two quetions i have are, 1. I know the intake clearance is a problem, but why cant we use the aftermarket intakes that edlebrock makes for the 2000 cobra r with the 5.4 in it. 2. What is the best solution for the exhaust as far as headers and x pipe go. Any info you guys can give me on the swap would be great and i would greatly appreciate it.
96 mustang gt
Ok, because i dont know i have another question, 1. Is the mark 8 motor a 4 valve and if so, which would be better, a mark 8 swap or a 5.4 swap. I want the most power out a swap and not sure which direction to head in. Any info would sure help. Thanks guys.
97 Mustang GT
slower than the speed of smell
im doing the 5.4 swap right now and i would personally go with a mark viii swap.
the mark viii is a 4 valve motor the 2000 cobra r is a 4 valve mustang, the intake problem is because the v of the engine is longer/wider so you need a corresponding intake that fits. HPS sells an intake for the 2 valve motors that fits under the hood and is quite nice. there is a company that makes long tube headers for the 5.4. i believe they are called FPS or TPS or something. go onto mustangboards.com and they will answer that for you. the answer to the exhaust problem (easiest at least) is to just have an exhaust shop lengthen your mid pipe to fit and done. |
1997 Pacific Green Cobra
14.80 No traction
sharkey knows allot about this. he did one. its awesome lol. Im working on a 5.4 DOHC swap now. going to be quite mean.
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
96 mustang gt
What cars can you get a dohc 5.4 out of?
Official Thread Killer
2006 Mustang
00.00@000.00
00-04 Linconl Navigator
Mark VIII (not sure on year) Cobra (really expencive and/or rare as hell) Just look up 5.4L InTech as that's the ford 4v DOHC 5.4L engine
96 mustang gt
Ok, cool. So the next question is, if i can actually find a 5.4l 4 valve, what do i use for a an intake and what for headers, any suggetions?
2006 Mustang
00.00@000.00
I have been looking into it, MMR makes a pricey intake mani, but I'll probably need it for stock hood use. They also make a 5.4L cobra replica mani (iirc) for a little cheaper, but I think the fully custom is a better flow rate
![]() Someone else may know more about headers as I'll be using the navi headers and cut them to fit when I start...
96 mustang gt
Ok, i guess this should ge a big question, will any of these motors run ok with my stock tuned 96 gt comp.
Rollin' 18/ pushin' 2
no, you are going to need a tune.
14.80 No traction
Will need to be tuned.
May not clear the Brake booster set up. Heads are very wide due to huge V block. Intake will be badassed and stick out of the hood. I have two blocks. a 5.4 and 4.6 Teksid. I have a few navigators and Mark VIII in New Orleans. too many of them really at the u pull it haha.
#12 | |
2006 Mustang
00.00@000.00
96 mustang gt
I wish i was a lil closer to new orleans id swing over and pick up an engine, lol, after everything i think i am going to go for the mark viii swap. Would like to find a cobra intake and tb to go on top of it though if anyone can help with that. Thanks for all the help guys.
14.80 No traction
Most cobra stuff i found were like 4-5 intakes for sale on Corral and svt performance. And yeah New Orleans down here is a gold mine for the best of the engine swaps. PI heads go for 50 bucks. intakes 25 bucks cams 25 bucks...... soooo many deals...
14.80 No traction
Ikr There always at least 20 different PI cars in the lot and all cars are up on stands and the ground is gravel its clean and organized by section.. i should make a mustang part business out of it haha.
I did thw mark swap and it was pretty easy. Look for a 97-98 its pretty much direct swap. Or you can get the engine from all mark 8 93-98
MM FOBRA CLUB MEMBER #1 |
2000 Mustang Gt
no clue
You can put the stock 2v 4.6 intake or an aftermarket intake on a 5.4 2v. You need adaptor plates. It might hold you back though.
Just because your cars loud doesnt mean its fast |
96 mustang gt
14.80 No traction
Its night and day o_o
Threads Similar to: 5.4 swap, need help please
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| pi swap or motor swap | whiteboy05 | 96-98 | 12 | December 8th, 2009 05:30 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
