pi cam swap
Old June 9th, 2007, 10:55 PM   #1
97_stang_gt is on a distinguished road
pi cam swap
ok so im lookin to swap in pi heads and cams...in order to avoid engine failure because of wear what should i make sure the heads come complete with...for ex...can i swap cam gears on a new cam..or does everything have to be new
Old June 10th, 2007, 12:31 AM   #2
Casper98GT's Avatar
Buy a set of 2002 - 2004 SOHC heads. They will be romeo heads and you can reuse youre cam gears and spacers. Buy a set of PI cam bolts though. If you have high milage you can throw on some new timing chains and guides. They should come all assembled ( heads and cams) New headbolts and headgaskets, valve cover gaskets, front cover gaskets, and a tube of silicone.
91 LX, 5spd.
Ex:Toyota/Ford tech
Threads Similar to: pi cam swap
Which one is easier??a rear end swap or engine swap? Bies08 V6 Mustangs 42 May 11th, 2010 04:33 PM
PI Head Swap and Transmission Swap jEEd 96-98 18 May 14th, 2009 12:57 AM
Can't decide, engine swap or PI swap? A few questions... k3vin 96-98 24 September 5th, 2007 06:48 PM
3.8 swap to 5.0 goldhorse V6 Mustangs 1 August 10th, 2007 12:57 AM
351 Swap Cskit1500 5.0 Mustangs 6 November 16th, 2006 07:40 PM
