Newbie 97 4.6l transmission problems If any one can help me with this. I have a 97 mustang gt with 132,000.00 miles and the clutch was replaced about 35,000 miles ago. The question is I can shift into 1,3,and 5th. But not 2,4, and reverse. There is no noise no grinding, it just will not move in those gears??? Its is like those gears are no longer there? Does anybody have any idea? Freinds told me its the sencrinisers ????? sry cant spell.. |
I doubt it's distinctly, each individual synchronizer causing it if there is not grinding at all. They might be screwed after whatever it was that happened inside the transmission. I'm going to let someone with more experience help you out with this one since I'm not sure how the t45 is set up exactly and I will probably give you the wrong info. The only thing I am thinking is probably way off from the problem. You are definately going to have to open it up and take a look at it to correctly find the problem whether you do it by yourself or take it somewhere.
what about the shifter stops? could that be casuing them to not go into those down gears?
Can I check the stops with out dropping the transmission? I havent a clue thankyou for your responce
yes
well first of all is it an after market short shifter?
No it should be the stock shifter. Nothing should be changed.
well your probably SOL then!
So I am prob looking at having to Drop the transmission?
yeah and getting a new one or having that one reuilt
Thanks for the Reply's......
So I am thinking about putting a t-56 in Is there much conversion's??? Would this be hard to do?
not hard at all takes a different crossmember, and different sized driveshaft. i want to do a rockland t-56 in mine!
Threads Similar to: Newbie 97 4.6l transmission problems
| transmission problems ? help !!!!!!!!!!!!!!11 | hughett17 | 5.0 Mustangs | 4 | August 16th, 2007 03:32 AM |
| Transmission problems | 03 R Code | 99-04 | 2 | April 23rd, 2007 04:03 PM |
| transmission problems | DeathScythe95 | V6 Mustangs | 5 | April 4th, 2007 11:31 PM |
| Transmission PROBLEMS. Help | White35ThGT | 99-04 | 3 | February 21st, 2007 10:47 AM |
| Having problems with my transmission | new 5.0 | 5.0 Mustangs | 6 | December 18th, 2006 02:52 PM |
