Discussing Lowered Stang Clunks When Shifting in the 96-98 Forum. Originally Posted by Casper98GT why would you put the stock snubber on...thats gonna make ...
Old June 13th, 2007, 12:58 PM   #21
ujslost's Avatar
why would you put the stock snubber on...thats gonna make things worse. trust me that noise youre hearing isnt from that e-brake rivet getting rubbed. you honestly think a clunk noise is being made by a small ring around it ? You have other problems. I have NO clunk and i have that ring around the DS due to the lowering as well. Im sitting on 2 inch drop. you need to check out the entire suspension.
yeah on my car it is from rubbing that ebrake thing. I know 100% I have had it on the lift before and seen where the both of them have nice shiney rub marks. So yeah I honestly think thats where my noise is coming from. And it never done it until I put the eibach springs back on. And by puttin the stock snubber back on it wont make matters worse. when the axle is loaded up the pinion angle goes up towards the bottom of the car. if a longer snubber were in place it wouldnt let it angle up so high, thus not letting the drive shaft rub the ebrake crossover.
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801
Old June 13th, 2007, 01:26 PM   #22
Casper98GT's Avatar
You may have that mark on youre ebrake rivet...as do i. I HAVE NO NOISE. So you cant say 100 its that doing it. And how would a longer snubber be a good thing.....you lowered the angle of youre car. You changed everything such as the travel of the rear end. Everything you just said completely makes me think otherwise of what i thought about you.
Im done with this post. Keep on going on as you have been .
White99stang-
Damn i miss the good ole days, you know in 2005 when the site first started and everyone wasn't getting butt hurt over every little thing
Ford/Toyota tech.
93 LX, H/C/I + Vortech
Old June 13th, 2007, 06:57 PM   #23
ujslost's Avatar
Thats cool. Im done with this forum. To many ppl think they know it all around here. And to much arguing about nothing that makes sense. Hope I spelt "sense" right for ya.
Old June 20th, 2007, 11:30 PM   #24
I got the same issue too with my Cobra. It's lowered with H&R springs, spring insolators and I feel the "bump" under hard acceleration.
Old June 21st, 2007, 01:03 AM   #25
slvrbllt98GT's Avatar
Yeah, I'm still hoping to get some time to crawl under mine this weekend and try to see what's going on. Have you taken a look at yours to see if you can determine what's causing it?
'98 Mustang GT
H&R Sport Springs, Tokico HP's, MM C/C's, MagnaFlow Cat-Back, Tri-Ax, Spec Stage 1, Ford Racing Flywheel, DiabloSport Tuner, K&N
Old June 22nd, 2007, 05:37 PM   #26
Ok, for the record, putting the stock snub on is a bad idea. Due to if your suspension trys to move up, your stoping it, and going to cause the car to take the bump instead of the suspension. So casper was right on that. But, the drive shaft could hit the ebrake stuff. And obviously with the shining spots it is. Get a hammer....
Fast, Cheap or Reliable. You get to pick TWO!
Old June 22nd, 2007, 05:46 PM   #27
I HAD THE VERY SAME PROBLEM THAT YOU HAD AND MY TRANNY MOUNT WAS BROKEN I REPLACED IT AN BOOM NOMORE CLUNK.. SO TRY DOING THAT
Old June 22nd, 2007, 06:28 PM   #28
ujslost's Avatar
Threads Similar to: Lowered Stang Clunks When Shifting
how much should it be lowered Iownastang 5.0 Mustangs 12 September 5th, 2007 09:09 PM
Car lowered Nameless122 V6 Mustangs 29 July 26th, 2007 01:30 PM
Long tubes + Lowered Stang??? Any problems??? Slowbra_12 96-98 1 July 24th, 2007 12:00 AM
some newer pics of the stang lowered, black corners...... Bossman Pictures 28 January 6th, 2007 06:02 PM
It's Lowered!!! ScreaminYellow05 V6 Mustangs 27 December 30th, 2006 05:26 AM
