Auto Trans Problem - Stuck in Park on my AOD
Old June 11th, 2007, 12:10 PM   #1
Sir Charles's Avatar
Sir Charles is on a distinguished road
So I go out to drive my '96 Stang out of the garage this morning and the tranny won't shift out of park. I look and there is a LOW OIL light on the dash. So I check the tranny fluid and it was low. I added 1 bottle to it, the levels was good again and the light went out, but still stuck in park. I did a search on here and couldn't find anything related to this problem. Has anyone experienced this and know what to do to get this corrected?
MILITARY CREW
E6
Modded Mustangs Military Thread
"A lack of planning on your end, doesn't constitute an emergency on my end" - Stacy Boudreaux
Old June 11th, 2007, 01:22 PM   #2
Casper98GT's Avatar
do you have brake lights ?
91 LX, 5spd.
Ex:Toyota/Ford tech
Old June 11th, 2007, 03:46 PM   #3
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
u think maybe the break sensor isn't registering? I would have never thought of it.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old June 11th, 2007, 04:43 PM   #4
Casper98GT's Avatar
yeah the shift interlock works off the brake lights switch on the pedal. If the wire is broken or the sensor melts then you wont beable to shift out.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old June 26th, 2007, 09:05 PM   #5
not at all.
MILITARY CREW
E6
Old June 26th, 2007, 09:06 PM   #6
I bought a brake/neutral cable with a solenoid from the dealer and installed it and nothing changed. I still have the problem. I am going to check my fuses.
MILITARY CREW
E6
Old June 26th, 2007, 10:35 PM   #7
The Hammer
G.T. Rags's Avatar
Millenium Falcon
is ur car just getting stuck inbetween P and N or is she not going into park with trouble getting the key outs
Old June 26th, 2007, 10:45 PM   #8
I start the car while it is in Park and it won't shift out of park. I turn the key off, turn the back back to the 12 o'clock position to disengage the solenoid and shift it to neutral so I can start the car and drive it. Once I park and shift it into park, it will not come out of park.
The keys come out just fine no matter what.
MILITARY CREW
E6
Old June 27th, 2007, 12:28 AM   #9
The Hammer
G.T. Rags's Avatar
Millenium Falcon
have u looked inside the shifter collumn. It may just need to be greased.
edit
guy in this thread had similar issue. At first i thought that urs was the same thread and was going nuts wondering what happened with the solution, but then realized it was someone else. Hope that helps.
http://www.moddedmustangs.com/forums...t-vt27207.html
Old June 27th, 2007, 04:57 PM   #10
jersey98gt is on a distinguished road
Send a message via AIM to jersey98gt
temporarily, you can put a key in the electronic shift lock underneath your steering wheel, to get you to and fro where you need to go
-BBK CAI, BASSANI CB + X, SCT 93 tune, 4.10s, Cobra brakes, Cobra R wrapped in nitto 555 tire.
-College Football and studies take up the bulk of my time.
Old July 10th, 2007, 10:03 PM   #11
Well I have changed out the Stoplight switch and the brake/neutral cable and it hasn't changed anything. I checked all of the fuses also just to play it safe and the problem is still there.
No brake lights, turn signals and it won't shift out of park.
MILITARY CREW
E6
Threads Similar to: Auto Trans Problem - Stuck in Park on my AOD
problem getting shifter out of park! 99greenmachine V6 Mustangs 2 July 6th, 2007 11:18 PM
Flush auto trans???? straight68 V6 Mustangs 4 December 21st, 2006 09:29 PM
Flush auto trans???? straight68 V6 Mustangs 1 December 21st, 2006 05:18 PM
Is The 5 Speed Auto Trans Able To Take 450hp? Globetrecker 2005 - 2010 16 December 8th, 2006 04:19 PM
deep pan for auto trans DILO2001GT 99-04 1 November 6th, 2006 10:29 PM
