Car won't fuckin start
Old June 11th, 2007, 11:23 PM   #1
sorrowfulkiller is on a distinguished road
I just let the car sit for about 20 mins and now it won't start... will turn over but won't crank... anti theft light is not flashing unless the key is in the crank position and a door is open. tried alternate key and the thing cranked once and won't again.... Any ideas?
Old June 11th, 2007, 11:50 PM   #2
Anyone?
Old June 11th, 2007, 11:52 PM   #3
Jorge is on a distinguished road
Lock the car again with your keyless entry. Use the panic button and turn off the alarm. Then use keyless entry to unlock the car and try to start it again.
Old June 11th, 2007, 11:52 PM   #4
droppedbass87 is an unknown quantity at this point
Send a message via AIM to droppedbass87
what year is it??
Old June 12th, 2007, 01:18 AM   #5
Old June 12th, 2007, 01:31 AM   #6
aww man i dont know..i have a 96 to..disconnect the battery for at least 2 minutes and then connect it back and then turn the key onto the crank position and let it sit a sec and then try cranking it a couple times..if it doesnt crank after that it might be something mechanically wrong with it...
Old June 12th, 2007, 01:44 AM   #7
tried that actually let it sit for 30 mins.... didn't work... I'll try again tommorow though. Along with the whole thing with the panic button.... its midnight right now... and I don't want to wake up people.... well my gf doesn't want me to xD
Old June 12th, 2007, 01:56 AM   #8
ok man i will get some other people on here to..
Old June 12th, 2007, 04:00 AM   #9
ujslost's Avatar
Well will the car even turn over? or it does nothing?
Old June 12th, 2007, 10:35 AM   #10
The Hammer
G.T. Rags's Avatar
Millenium Falcon
G.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant futureG.T. Rags has a brilliant future
Did this happen all of a sudden of did u mod the car. Maybe put a deck in, messed with the electrical. Anything? I'm not suggesting u did, only asking so people can help diagnose u a little better. It's hard not being right there looking at it with u.
I would eat the peanuts out of her shit
Car Salesman Club - The Hammer
ModdedMustangs Conspiracy Group: President
Old June 12th, 2007, 10:38 AM   #11
The Hammer
G.T. Rags's Avatar
Millenium Falcon
i was reading u other post and saw u had a coolant leak and had to clean the plugs. Did u unplug any of them. If so u may have crossed one or two of them.
Old June 12th, 2007, 10:45 AM   #12
beheivjer's Avatar
beheivjer is on a distinguished road
put the key in the ignition and turn to on but dont try to start, leave it there and count out 30 secs and then try to start it and if it starts you have the same type of problem i have wih the pats marriage system
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old June 12th, 2007, 11:14 AM   #13
I didn't mod the car recently, all the wires are in the right spot.... I have driven it in the past 2 days with no problems...
The car doesn't crank at all... it turns over like normal but doesn't crank and still has power when you try to turn it on.... brake light comes on and I think the coolant light comes on too.... but I'm pretty sure that has nothing to do with it
Old June 12th, 2007, 11:15 AM   #14
well actually I did put new spark plugs in... has worked for 2 days since then though
Old June 12th, 2007, 11:24 AM   #15
beheivjer's Avatar
NO CLICKETY clickety or anything?
1979 2.3t Cobra
1997 Black Cobra
Old June 12th, 2007, 11:30 AM   #16
no clickety clickety xD
I did say it won't crank at all right?
Old June 12th, 2007, 11:32 AM   #17
I haven't tried anything since last night... too lazy to get dressed but once I get dressed I'll go out and try a couple of these ideas
Old June 12th, 2007, 11:35 AM   #18
The Hammer
G.T. Rags's Avatar
Millenium Falcon
i had an issue with my chevy last fall. Car used to get jammed in park and drive, eventually the cable the connected the ignition to the shifter(auto) was to sticky and dry and sometimes my key wouldn't release from the ignition, or start. no crank or nothing. i'd have power but no clickety click. is your car auto or manual? I just lubed it like ten times and no problem
Old June 12th, 2007, 12:39 PM   #19
Auto
Old June 12th, 2007, 12:48 PM   #20
The Hammer
G.T. Rags's Avatar
Millenium Falcon
check to see if your cable is connected or dry. I know mine went because I had spilled lke 50 slurpees in it over the summer. I unfortunately had a job that required me to almost live out of my car, and i had crappy cupholders. now i don't even allow ingestion of food in my vehicle. My gf has to beg my and pretty much sign a liability statement.
Threads Similar to: Car won't fuckin start
Wooo Hooo its mutha fuckin friday WilltheThrill The Clubhouse 22 November 2nd, 2007 04:32 PM
Now this is a fuckin burnout Juggalo_X The Clubhouse 23 October 16th, 2007 05:12 PM
Fuckin body shops! Garhfer The Clubhouse 12 September 8th, 2007 01:45 AM
Where should I start? briggs32586 2005 - 2010 2 May 25th, 2007 07:08 AM
Where to start? JBake V6 Mustangs 6 October 24th, 2006 12:43 AM
