Steering Noise
Old June 14th, 2007, 08:24 PM   #1
xx9gt6xx is on a distinguished road
Send a message via AIM to xx9gt6xx
Steering Noise
Hey guys I need help diagnosing a noise my car makes when I go to steer. As I'm steering there's a groaning noise coming from underneith where the rack and pinion is at. I know it's not the power steering pump or the belt slipping because if I were to turn and hold the wheel then it would continue to groan but it only does it while I'm turning the wheel. The noise is very faint on the outside while I'm steering but you can really hear it inside the car. Inner or outer tie rods? Rack and pinion trouble? Please help me out!
...Modded 1996 Ford Mustang GT... SOLD!!
...Modded 2001 Ford Mustang SVT Cobra... SOLD!!
Now...
...Modded 2003 Ford Mustang SVT Cobra, Anniversary Edition..
www.cardomain.com/id/po1snd_u
Old June 14th, 2007, 10:32 PM   #2
slvrbllt98GT's Avatar
slvrbllt98GT is on a distinguished road
I have the same problem... only mine is definitely not faint... it's loud! I took it to a mechanic and they swapped out the steering rack bushings (3 times to be exact). It still makes that creaking noise. So much for that mechanic.
'98 Mustang GT
H&R Sport Springs, Tokico HP's, MM C/C's, MagnaFlow Cat-Back, Tri-Ax, Spec Stage 1, Ford Racing Flywheel, DiabloSport Tuner, K&N
Old June 15th, 2007, 12:43 PM   #3
So did you ever figure out what it is?
Now...
Old June 15th, 2007, 02:34 PM   #4
98KBYellowSVT's Avatar
98KBYellowSVT is on a distinguished road
my cobra is doing the same exact thing and its loud as crap. Its in the shop now getting new control arms and bushings but the last guys post just said that he has swapped his numerous times with no effect im debating whether to cancel.
Old June 15th, 2007, 02:40 PM   #5
Casper98GT's Avatar
Its really not hard to find out where its comming from.
I have told people on here millions of times the Ball joints make noise, and the tie rods.
All you gotta do is get under it and have someone turn the wheels back and fourth. The steering rack shouldnt have been replaced that many times.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old June 15th, 2007, 06:19 PM   #6
Does yours make the noise only when it's hot out? Mine does it only when it's hot. When it's in the 60's or below it doesn't make a peep...
Now...
Old June 15th, 2007, 06:25 PM   #7
Casper98GT's Avatar
yes it will make the noise worse when its hott.
91 LX, 5spd.
Ex:Toyota/Ford tech
Old June 15th, 2007, 11:28 PM   #8
Mine just started making the noise about 2 weeks ago so I really havent had any different weather conditions to compare.
Old June 15th, 2007, 11:47 PM   #9
Boomer is on a distinguished road
Send a message via AIM to Boomer Send a message via Yahoo to Boomer
As usual I am going to agree, I have a unrealted vehicle that does the same. After inspecting everything I found the ball joints were shot. I noticed the noise last summer,it stopped in the winter and started again at the first sign of warm weather...
Old June 16th, 2007, 02:06 AM   #10
EXACTLY!!
Now...
Old June 18th, 2007, 12:37 PM   #11
shadow98gt's Avatar
1998 Mustang GT
shadow98gt is on a distinguished road
i have the same noise and it only makes it while the car is underload(if i put on a lift and turn the wheels nothing happens) and only on the right side, i talked to my mechanic who knows pretty much anything and he says its the ball joint, so im gonn areplace it this week....
Quit smilin your drivin a camaro!!
Mods:
Currently going through a sex-change. Going in Michael jackson coming out Kimbo Slice!!
MM Cobra Member # 87
Threads Similar to: Steering Noise
steering noise Blackbeauty v601 V6 Mustangs 10 August 10th, 2007 08:24 PM
power steering noise.... ibanez570x 99-04 5 January 25th, 2007 12:33 PM
Steering Shaft Noise Black Bullitt 99-04 2 January 18th, 2007 10:00 AM
Noise When Steering MikeD General Tech 13 October 13th, 2006 09:04 AM
Creaking noise during steering hudini General Tech 5 April 25th, 2006 05:46 PM
