1998 Mustang GT
![]() iTrader: 1 reviews
Car Bucks
I have a 98 GT and when i just give my car a lttle gas its bucks pretty bad, it doesnt do it all the time just when it feels like it... i have replaced coil packs, wires, and plugs so i dony know what else i can do... i also cleaned out my plenum and no help... any suggestions?
Quit smilin your drivin a camaro!! ![]() Mods: Currently going through a sex-change. Going in Michael jackson coming out Kimbo Slice!! ![]() MM Cobra Member # 87 |
Proud American
Do you have a CEL?
Are you sure you gapped the plugs correctly?
1998 GT FRPP: 4.10s, Alluminum d/s STEEDA:upper/lowers, springs, cc plates, tri-ax TOKICO: Adjustable shocks SPEC: alluminum flywheel K&N: Intake Screamin Demon ignition ram: clutch ----------------------- BUCK OFAMA |
1998 Mustang GT
i dont know what a CEL is and yea i just bought plugs that fit my car... but it has been doing this for awhile and i dunno!? it usually does it after i am rough on it, but then sometimes it just does it to piss me off...
Just cause they fit, doesn't mean they are gapped correctly take one of them out and check the gap. Does it buck under a low rpm load?
1998 Mustang GT
yea but its more about gas... if i just give it gas it bucks but if i give it a good amount of gas it is fine and pulls good so idk
1998 Mustang GT
what should the gap be? and what do i use to check it? sorry for all the questions i just am pissed off with this whole bucking problem
1998 Mustang GT
.056 or .054?
I have had good luck at .052", I was told to try it and have now seen a few books that list it at .052". Also check all your wires, one may not be on all the way causing it to jump a gap to reach the plug.
1998 Mustang GT
ok i check the wires but im almost positive it has to do wit the gap beacud=se the wires are all new and i snugged them all up and used the deelectric grease on the boots
Proud American
Make sure that the plug boots are pushed on to the plugs completely! Also do you have a CEL? Check Engine Light!
Have you checked your injectors? One could be clogged...
Parting out 2003 SVT Cobra Air/Fuel http://www.moddedmustangs.com/forums...003-cobra.html Engine http://www.moddedmustangs.com/forums...003-cobra.html |
1998 Mustang GT
i do have a check engine light but it was for my O2 sensor and it goes on and off and the injectors have been cleaned, i put in fuel injector cleaner every 3,000 miles but i will double check my plug boots and if not just get new plugs...
Proud American
I say that you go and get that code read, because IMO it is probably a misfire on one of the cylinders and then you can figure out which one to fix!
If you have stock coil packs I would gap the plugs to .052, you can get a spark plug gapper at any auto parts store.
I think you guys are making this more complicated then it is. He already said that he didn't gap the plugs, having incorectly gapped plugs can cause it to buck under low rpm/part throttle load, but not at WOT.
BTW using that fuel injection cleaner too often is bad for your car. Once every other oil change is more than sufficient.
2006 GT
11.99@114
Might be time for a new fuel filter. When was the last time you changed it?
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
1998 Mustang GT
never changed the fuel filter and i will go to the auto parts store and buy a gap tool, but i dont think its gas because it feels like a misfire its not cutting out.
1998 Mustang GT
o and i have msd coli packs...
Threads Similar to: Car Bucks
| $300 Bucks to blow..... | jrfan4life | 99-04 | 9 | November 8th, 2007 02:34 PM |
| 600 bucks to blow | superbeef1000 | 99-04 | 8 | September 16th, 2007 01:00 AM |
| $200 Bucks it is... | TurboLX | The Clubhouse | 8 | August 7th, 2007 12:34 AM |
| 1500 Bucks To Spend | purplepony96 | 96-98 | 20 | November 12th, 2006 04:18 AM |
| 96 GT Bucks When AC Is On Help | jagstang96 | 96-98 | 5 | September 10th, 2006 07:23 PM |
