Discussing Help!!! Car keeps dying in the 96-98 Forum. Ok, i had a new clutch put in last night, it was finished this morning. ...
Old June 16th, 2007, 02:59 PM   #1
NMR-2vGT's Avatar
1996 GT
Too Slow....
Ok, i had a new clutch put in last night, it was finished this morning. It was adjusted and everything. But when i slow down and push in the clutch to stop the RPM doesnt stop at the idle, it just keeps dropping and dies. I have to restart it but it starts right back up. The clutch feels fine. Also my radio turns on and off. Is there a short somewhere or what could the problem be?
Old July 7th, 2007, 01:40 AM   #2
Did you get your car fixed?
I take it you disconnected the battery when you removed your starter. I would start there. Check the battery connections and the connection to your engine bay fuse box.
When your car stalls does the whole car die? If so, check the ground to the engine block behind the oil filter as well.
The only ground that would have been affected is the battery ground itself.
I do not see anything else obvious looking through the schematics.
Good Luck!
314RWHP 343RWTQ
NON PI HEADS 8 PSI P-1SC W 3CORE I/C
03 IRS, TREMEC 3550, JBA SHORTIE'S
MM SUSPENSION, BORLA STINGERS
BASSANI CATTED X
Threads Similar to: Help!!! Car keeps dying
Car just dying 96GTRagTop 96-98 18 October 17th, 2007 11:11 PM
As I Lay Dying Nameless122 The Clubhouse 3 August 20th, 2007 04:56 PM
dying mustang. patwrecked 5.0 Mustangs 4 March 30th, 2007 04:09 AM
Wow my friend is dying ... no literally , hes dying Youngin The Clubhouse 30 February 10th, 2007 04:01 PM
dying interior motoking69 5.0 Mustangs 5 December 10th, 2006 04:08 PM
